Post by seanrd on Apr 28, 2013 19:16:07 GMT 1
So after the DVLA have messed me around and HMRC failing to help, I thought bollocks to it! New frame. UK bike this time so no problems...Just a bit of work needed to get it where I want it. Drove 380 mile on Friday to pick this up. Apart from a numb bum from the drive I'm chuffed to bit with it. Another long drive to Stafford for the Classic show and a shopping list of various grinding discs, blades and various other stuff on Saturday meant I could crack on this morning with converting it to rising rate suspension and a few extra braces. So it begins! Removed the original footrest hanger mounts to make way for the new ones i use. At some point someone professionally fitted a belly pan...This needs sorting but no biggy. They need their tools confiscating Wiring loom lugs....de-lugged Steering lock, lock stops and wiring guide removed to make way for my own design Centre stand tube removed to make way for the new one Side stand spring mount punched out to be put in on the outside New bottom square section bottom tube New top tube to go in for the top shock mount New bracing That's it for today ;D
Post by sidney on Apr 28, 2013 19:32:55 GMT 1
so wots the crack with this then mate ? ,im not mr current affairs lol
Post by seanrd on Apr 28, 2013 19:47:12 GMT 1
Post by Norbo on Apr 29, 2013 8:42:03 GMT 1
Thats some nice fitting brackets you got there.
Post by billyboy on Apr 29, 2013 22:26:37 GMT 1
bugger to have to go to all this trouble ,how did you find a uk frame so quick ?
Post by copper99 on Apr 29, 2013 22:31:28 GMT 1
What was the ag with the non UK frame mate?
Got me worried that the frame im considering buying isnt a UK item now, it has a V5 thou..
Where abouts in Beds are you, i could do with some help(over the phone) with mine now and again, I do a motorcycle parts collection service in exchange!
Look forward to seeing the build come along.
Post by billyboy on Apr 29, 2013 22:41:52 GMT 1
how can it not be a uk frame if it has a v5 ?
Post by bryan on Apr 30, 2013 17:44:40 GMT 1
if you have a UK V5 matching the numbers on the frame your ok. The problem is regestering a frame from another country if you dont have a stamped VAT form from HMRC.
Post by seanrd on Apr 30, 2013 20:34:52 GMT 1
Spot on Bryan! Have a gift in the post for you. Should be there tommorow!
Post by midlifecrisisrd on Apr 30, 2013 20:53:30 GMT 1
if you have a UK V5 matching the numbers on the frame your ok. The problem is regestering a frame from another country if you dont have a stamped VAT form from HMRC. I'm a very lucky boy, got my 386 today dated 14th April Steve
Post by bryan on Apr 30, 2013 21:23:31 GMT 1
Spot on Bryan! Have a gift in the post for you. Should be there tommorow! been waiting 3 years, thanks You making the frame wire guide too
Post by seanrd on Apr 30, 2013 21:42:42 GMT 1
I've got to do one for this frame, do you need one then?
Post by bryan on Apr 30, 2013 22:28:40 GMT 1
no, just noticed it wasnt on it.
Post by seanrd on Apr 30, 2013 23:14:24 GMT 1
It was on there just bent and twisted. 5 minute job to make a new one
Post by bryan on May 1, 2013 17:42:07 GMT 1
got it today Sean, thanks very much.
simch
Post by simch on May 12, 2013 9:51:37 GMT 1
That's some neat work. What you doing with the old frame?
Post by bryan on May 17, 2013 23:03:24 GMT 1
Come on Sean, post some pics up!
Post by seanrd on May 18, 2013 2:33:50 GMT 1
Yawwwwwn! 8 till 4 at work then straight into the garage with a bare frame and wheels. Tyres fitted, balanced and it's now running! Few little wiring bugs to sort in the morning but it's look good 3am and i'm going to bed!
Post by bryan on May 18, 2013 11:48:01 GMT 1
good effort Sean
Post by seanrd on May 19, 2013 0:03:17 GMT 1
Sorted all the bugs and niggles out today, down to my cack soldering on one of the indicator wires.... Just coolant and tank to go
Post by bryan on May 19, 2013 15:01:35 GMT 1
oy!
Post by seanrd on May 19, 2013 18:20:59 GMT 1
Bryan's seen a pic Martin
Post by Roofmonster on May 19, 2013 19:59:05 GMT 1
Hey Seany,are these feckin pictures still down the developers LOL A camera from the 80s too? ;D
Post by bryan on May 19, 2013 20:06:22 GMT 1
You are a talented bloke Seany look in the finnished Hybrids section.
