Post by Deleted on Sept 18, 2007 17:33:45 GMT 1
whats going on? i had 3 gold stars, now i got two green ones! how does that work then, gold, green, blue, bloody mystery to me
Post by Norbo on Sept 18, 2007 19:59:23 GMT 1
You start with 1 small gold then 2 then 3 . Then you get 2 blue and they go up and change to green then in the end you get red . Have you noticed your name below has changed aswell now.
Post by Deleted on Sept 18, 2007 20:01:37 GMT 1
You start with 1 small gold then 2 then 3 . Then you get 2 blue and they go up and change to green then in the end you get red . Have you noticed your name below has changed aswell now. yep noticed the name change, how come you have 10 gold then?
Post by scott on Sept 18, 2007 20:40:40 GMT 1
You start with 1 small gold then 2 then 3 . Then you get 2 blue and they go up and change to green then in the end you get red . Have you noticed your name below has changed aswell now. yep noticed the name change, how come you have 10 gold then? cause norbo's the daddy ;Dit goes on how many post's you've made.the more post's u make the more stars u get. unless u know the daddy and become a global moderater like 2 certain cheeky monkeys on ea ;D ;D
Post by Norbo on Sept 18, 2007 20:47:45 GMT 1
a couple of hundred more and scotts will turn red and start going up with a new name change
Post by scott on Sept 18, 2007 20:50:57 GMT 1
a couple of hundred more and scotts will turn red and start going up with a new name change couple more hundred,can't u bump em up for me norbo ;D
