Post by stevenm7421 on Apr 18, 2013 12:52:19 GMT 1
hi all, just joined & wonder if anyone has any clue to the problem i have with my new build,almost completed runs spot on, in neutral,soon as i put it in gear it dies? ???any input would be good cheers in advance.
Post by raven13 on Apr 18, 2013 13:24:16 GMT 1
is your clutch adjusted properly. could be dragging and putting load on the engine. this could cause it to die.
Post by steve h on Apr 18, 2013 13:35:44 GMT 1
Is there a sidestand switch on these models?
Post by raven13 on Apr 18, 2013 13:39:21 GMT 1
Is there a sidestand switch on these models? no side stand switch on the rd125lc
Post by stevenm7421 on Apr 18, 2013 21:05:14 GMT 1
thats the first thought i had,however i have used a tzr loom which has a side stand switch,i think if i connect one we should be in buisness,let you know,.ps thanks for reply...
Post by raven13 on Apr 18, 2013 22:34:49 GMT 1
if you have used a tzr loom then you will need to join the 2 wires that feed the switch, should solve the problem.
Post by Norbo on Apr 19, 2013 7:16:04 GMT 1
If you put it in gear and then kick it up and look at the plug and no spark im thinking the same as every one elce could have a tzr loom fitted and side stand switch
