Post by raven13 on Apr 14, 2013 19:41:51 GMT 1
are there any bigger cc barrels that will fit straight onto any model of the rd125lc thinking of having a change of direction
Post by twostroker on Apr 14, 2013 22:44:19 GMT 1
autissa 175cc probaly spelt wrong or fahron can resleeve yours to 175cc
Post by Norbo on Apr 15, 2013 7:26:59 GMT 1
As above nothing elce will just bolt on
Post by raven13 on Apr 15, 2013 18:55:02 GMT 1
anyone got an idea how much it costs. and do i need to be sat down wen i find out??
Post by Norbo on Apr 16, 2013 7:14:26 GMT 1
its about £180 to £200 for a 175 job using IT 175 pistons
Post by raven13 on Apr 16, 2013 19:08:48 GMT 1
what other mods to the engine would i need to make?
Post by Norbo on Apr 17, 2013 6:57:01 GMT 1
you need to get a TZ750 O ring for the barrel as they are O ring barreled . you will ned to grined back the bottem casing to match the new 175 CC you have to get your head done to match . You have to run pri mix the pump is no good now . Its just to big and to fast for the 125 pump . thats it realy other then fitting a bigger carb to feet the e xtra power. the standard 24mm one will run it but is restrictive.
Post by billy on Apr 20, 2013 15:04:28 GMT 1
I bet there are some old YZ 80 or 125cc barrels that fits with a little bit of modding. The problem is that no-one seem to know which barrel/s that might fit nicely!
