Post by ferret79 on Mar 2, 2013 19:53:39 GMT 1
hi all, brought this big bore kit a few years ago for my rd125lc, never got around to fitting it problem i've got is im wanting to know if its a autisa kit? i cant find any part numbers model numbers etc on the barrel, it came with the normal 10v head from doing a bit of research on the net it looks just like the autisa big bore kits any help would be great thanks
Post by Norbo on Mar 4, 2013 9:37:18 GMT 1
Id say yes it is they have a smoth barrel just like your one and you mod a standard head to fit just like your one . I would O ring the barrel though as head gaskets for them re hard to fined.
Post by billy on Mar 5, 2013 15:58:53 GMT 1
I don't know what barrel it is, but I know it's not a stock barrel that has had a 175 cc liner put in anyway. The stock barrels doesn't have those small "ribbons" on the inside where the coolant flows. Also, your barrel looks all flat on the sides, where the stock ones looks the same as the head does with the stepped edge etc.
Post by ferret79 on Mar 6, 2013 18:54:38 GMT 1
thanks chaps, i was thinking thats what it was, but as it had no markings at all wasnt 100% sure, now do i keep it, or clean it up and sell it? lol looks like it will need a rebore, measured the bore at 66mm but its slightly scored, to much for cylinder hone to sort.
Post by billy on Mar 8, 2013 16:51:25 GMT 1
thanks chaps, i was thinking thats what it was, but as it had no markings at all wasnt 100% sure, now do i keep it, or clean it up and sell it? lol looks like it will need a rebore, measured the bore at 66mm but its slightly scored, to much for cylinder hone to sort. That would depend on where the scratch is. If it can effect the compression, you might want to have it rebored, but if it's below the ports, it's usually no major drama. Just check so the ring/s won't snag it.
Post by ferret79 on Mar 12, 2013 17:17:23 GMT 1
dont have it it front of me at the moment, but i think its roughly middle of the barrel, around location of ports, so would need rebore
Post by joshwaudby on Apr 24, 2013 18:20:22 GMT 1
how much gain will you get from that?
Post by Deleted on Apr 27, 2013 0:09:40 GMT 1
depends what you mean about 'gains'.... Big bore kits do different things to different bikes, your not gonna get x mph on the top end if that's what your thinking, it will give greater torque though, through the rev range but also put additional pressure on the other moving parts of the engine. On the 125lc it should once set up correctly (i.e. carb settings etc) increase torque which will improve engine drive i.e. acceleration and if a bigger front sprocket fitted have the extra power to pull a slightly higher top end speed. Don't expect instant miracles with a big bore kit on a small cc bike it just doesn't happen........ (for that you want NOS lmfao.......
