Post by a13bee on Feb 18, 2013 23:48:47 GMT 1
can anyone help i have put a set of banshee coils on my 350r and what a difference it has made and was wondering if its possible to put a set on my 400c without blowing anything up regards to all a13bee.
Post by steve h on Feb 19, 2013 1:07:35 GMT 1
400C has 2 coils. Each with a primary resistance of 1.4 Ohms. The banshee coils have a primary resistance of 0.28 - 0.38 You realy need to find an upgrade coil with a simillar primary resistance. Otherwise you will burn out the wiring. (400c ignition gets its power from the general electrical system, the LCs get theres from a separate coil within the alternator.) Before you do any coil changing, consult an expert. Steve
Post by steve h on Feb 19, 2013 1:08:36 GMT 1
Hope my memory is right!!!!!!!
Post by marddy on Feb 19, 2013 6:20:29 GMT 1
Hi a13,
Is your C on CB points? If they are, then your bike runs on DC...ie battery feeds the current to the coils.
Banshee runs on AC...ie does not require a battery to power the coils.
If you fit Banshee coils to DC, it will blow the coils.
If you want to fix higher rated coils in C, pick up any modern day DC coils.
Post by Norbo on Feb 19, 2013 10:58:08 GMT 1
You can not fit them to a points A/C NO they will fit to the E and F that run a stator and cdi as i have sold a set to a bloke who has done this .
Post by a13bee on Feb 19, 2013 15:20:05 GMT 1
many thanks to all looks like i wont be fitting banshee coils on the 400 then have you got anything uprated to fit the old 400 norbo regards a13bee.
Post by Norbo on Feb 20, 2013 8:32:15 GMT 1
sorry no all i can do it a convershon to stator and cdi but nothing that just plugs in to what you have sorry just standard replacement stuff nothing trick .
Post by a13bee on Feb 20, 2013 23:31:49 GMT 1
many thanks norbo so what have you got for me coil wise and how much with post many thanks colin/a13bee.
hazey
Post by hazey on Feb 20, 2013 23:48:25 GMT 1
many thanks to all looks like i wont be fitting banshee coils on the 400 then have you got anything uprated to fit the old 400 norbo regards a13bee. Should ave bought a 400F ya tart Ask mervin col he knows the sketch with decent coils for points set up
Post by a13bee on Feb 20, 2013 23:53:00 GMT 1
ha hazey hows it going bro
hazey
Post by hazey on Feb 21, 2013 0:16:07 GMT 1
ha hazey hows it going bro just chillin mate Haaaaaaanggg Haaaaaaanggg Haaaaaaanggg Haaaaaaanggg or one of my favorites
Post by a13bee on Feb 21, 2013 0:22:42 GMT 1
mate cant stop doing it hanggggggggggggggg hangggggggggggg hangggggggggggggggg hangggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggg.
Post by a13bee on Feb 21, 2013 0:24:55 GMT 1
mate the tz is music to my ears better than bud 66 hangggg hanggggg hanggggg
