Post by tout on Feb 5, 2013 19:07:54 GMT 1
what is for best ?
Dry fittment, smear of grease ? gasket gloop ?
Post by Norbo on Feb 6, 2013 8:53:26 GMT 1
I allways put some clear instent gasket on both sides.
Post by tout on Feb 6, 2013 13:11:42 GMT 1
Cheers for the info
Post by billy on Feb 8, 2013 13:40:55 GMT 1
I think they should be dry fitted to a very clean, very flat and very dry surface tbh. I dry fitted my 125 head gasket and it doesn't leak. These gaskets have a black finish on them, that black finish is the actual sealant!
Post by looey on Feb 8, 2013 15:19:20 GMT 1
Up till a couple of years ago when you bought a genuine Yamaha head gasket it was a thick single piece gasket with a sticky tar like finish both sides and they used to seal 100% without any sealant.
The last couple of genuine Yam I have purchased are these horrible multi-leaf metal contraptions (exactly the same as pattern ones have always been) and I find they need a thin smear of either clear silicone or I have used a thin smear of 3-bond either side which both worked well.
Post by tout on Feb 8, 2013 19:02:40 GMT 1
Thanks Chaps, its had a thin smear of gloop !
Post by ferret79 on Feb 13, 2013 21:03:36 GMT 1
i always use genuine yamaha on mine, but find that the multi plate leaf comes apart and leaks so always use a bit of sealent
