Post by Roofmonster on Feb 3, 2013 15:57:29 GMT 1
Thanks to forum members furnishing me with a wiring diagram (many thanks oldelsieboy & marsbar) I have traced my ignition problem down to the coil - there is no resistance on the hf side. Where is the best place to get a replacement? I have seen some aftermarket ones on ebay, has anyone tried them? I could probably pick up a second hand one easily enough but it may be better to get a new replacement if possible.
Post by Deleted on Feb 3, 2013 16:35:26 GMT 1
norbo sells banshee coils i have them fitted to my bike, £40 a set and did a thread how to fit them in the how to section and they are very very good
Post by Roofmonster on Feb 3, 2013 17:00:38 GMT 1
Thanks guys Banchee coils seem the way to go!
Post by Denzil on Feb 3, 2013 20:57:44 GMT 1
I also have them fitted to my N2, the difference in spark when I was building my engine was phenomenal, the spark on the stock coil was very weedy, Banchee coils the spark was about 2mm and as others have said they do seem to run better with them.
Post by muttsnuts on Feb 4, 2013 12:45:01 GMT 1
I have a set of the Banshee coils and will be doing a back to back run of them against stock coils at the weekend, so will post up the difference
It was meant to be this weekend but my mate was upto his neck in racing bikes so the dyno wasn't free unfortunately
The spark is definately better that's for sure
iainw
Post by iainw on Feb 4, 2013 13:44:44 GMT 1
I too have the Banshee coils from Norbo, the spark is visibly bigger and fatter and the bike seems to run better. It now starts first kick from cold instead of second. The real proof of the difference will be when muttsnuts has his on the dyno.
Post by Roofmonster on Feb 4, 2013 15:05:35 GMT 1
I am ordering some from Norbo today. They look easy enough to fit too, with only a small bracket to make. It looks like they are wired in series in the "how to" pic. Is this correct? - Its not completely clear in the picture.
Post by muttsnuts on Feb 4, 2013 20:42:59 GMT 1
I'll take a picture of mine as they are off the bike at the moment so you can see how its done ! hereyago hope that helps BTW - that's just a quick mock, I'll be making a proper loom and brackets for it when its all sorted !
Post by Roofmonster on Feb 4, 2013 22:03:50 GMT 1
Thanks mutts - that makes sense now - they are wired in parallel.
Post by muttsnuts on Feb 9, 2013 16:56:45 GMT 1
I've just done a back to back test on a dyno wtih the standard coil pack and the Banshee ones from Norbo and there is definately a gain throughout the rev range, overall my bike gained 1BHP throughout the rev range but more imporantly it revs much cleaner,. throttle response is so much crisper but also the bike starts a whole lot easier as well and my bike has always been a 1st/2nd kick starter
Post by marsbar350 on Feb 9, 2013 17:01:14 GMT 1
thats good news dave ;D micks got them on his and he said there was an improvement now its in black and white.you gotta believe him ;D id say norbs will sell a few ;D
Post by muttsnuts on Feb 9, 2013 17:11:24 GMT 1
yeah, I should get some commission of Norbo now !! - in my dreams anyway !!
Still, it was good to see it for real, even my mate who has been doing this stuff for more years than even I care to think about said it was a noticeable difference.
Post by Roofmonster on Feb 9, 2013 17:13:15 GMT 1
Certainly worked a treat on my LC - started easily after a long lay up and you could definitely see the difference in the spark. I've not ridden it yet (as I need to rebuild the brakes) but I will let you know. As i don't run an airbox I fitted them in tandem rather than making a bracket to fit them side by side and they went in easily - I will take some photos when it gets warm enough for me to go out in the shed!!. Many thanks for all your help and to Norbo for such a prompt service .
Post by skydemon on Feb 9, 2013 17:24:12 GMT 1
Mutts maybe worthwhile knocking up some brackets for Norbo. I am sure he will trade you something for them ;-)
Post by muttsnuts on Feb 9, 2013 18:34:55 GMT 1
yeah, he'll have to put an order in wth me and I'll sort out a price !!, maybe do the looms as well for him !
Post by sp885 on Jun 13, 2015 4:07:53 GMT 1
Dragging up an old thread here guys I know, but does anyone do these looms for the Banshee Coils? I got a set of Norbo a while ago, but haven't fitted them yet as I am not much good with anything elektrickery Cheers Steve
