Post by woodentopp on Jan 25, 2013 11:18:13 GMT 1
Anybody know what the tyre sizes are for the original spoked wheels (disc brakes) on the RD 250/400?
What are other tyre options?
Can you fit twin discs to the front? Cheers.
Post by 4ce on Jan 25, 2013 20:38:50 GMT 1
The alloys are 90/90 H18 front and 110/80 H18 rear I would imagine the spoked wheels are the same. I run Bridgestone BT45s on mine. You can fit twin discs but you need to fit a fork leg with mounting points. I heard XS500 forks are the same.
Post by woodentopp on Jan 26, 2013 11:34:24 GMT 1
Thinking of fitting them to my LC2 so the fork mounting isn't a problem. Cheers for the info
Post by oldelsieboy on Jan 26, 2013 12:01:47 GMT 1
The 250/400 front hub does not have fittings for a twin disc setup.
OEB
Post by Splodge on Jan 26, 2013 12:48:00 GMT 1
I have a pair of these knocking about I will go and see what tyres sizes are on them ........... Front 3.00 - 18 REINF .52P Rear 100/90 - 18 Hope that helps
Post by oldelsieboy on Jan 26, 2013 13:21:35 GMT 1
I have a pair of these knocking about I will go and see what tyres sizes are on them ........... Front 3.00 - 18 REINF .52P Rear 100/90 - 18 Hope that helps Original sizes were probably 3.00 x 18 front, 3.50 x 18 rear. OEB EDIT: Just checked the parts fiche, rear was 3.25 x 18
Post by woodentopp on Jan 26, 2013 17:01:57 GMT 1
If the front wheel does not have a fitting for twin discs why is Norbo selling a blanking plate for the front wheel (spoked and alloy)?
Post by oldelsieboy on Jan 26, 2013 18:16:40 GMT 1
If the front wheel does not have a fitting for twin discs why is Norbo selling a blanking plate for the front wheel (spoked and alloy)? According to the E model parts fiche the spoked front wheel hub has fittings for twin disc that is why there is a blanking disc available. But, again according to the fiche, this particular wheel was only available in the UK. I'm no AC expert but I think that particular hub a very rear item indeed. HTH OEB
Post by woodentopp on Jan 26, 2013 18:44:55 GMT 1
Cheers for the help.
Post by Paul Dawkins on Jan 26, 2013 19:57:31 GMT 1
The rear hub is very sought after as the TZ boys use them. I have seen them fetch £300 just for the hub
Post by Splodge on Jan 26, 2013 21:10:17 GMT 1
The rear hub is very sought after as the TZ boys use them. I have seen them fetch £300 just for the hub Thats worth knowing maybe I will put mine up for sale
Post by Paul Dawkins on Jan 27, 2013 17:29:56 GMT 1
Post by buckshot on Jan 28, 2013 15:24:49 GMT 1
The 250/400 front hub does not have fittings for a twin disc setup. OEB Correct. Left hub in picture is a front hub Respoked with stainless spokes.
Post by gazzatt2 on Jan 28, 2013 22:49:04 GMT 1
the E/F spoked hub does have the fittings for a 2nd disc i have one on my sprint bike
Post by Splodge on Jan 29, 2013 0:45:10 GMT 1
Bloody hell I didn't think they were worth that kinda doe ;D
Post by buckshot on Jan 29, 2013 11:48:06 GMT 1
the E/F spoked hub does have the fittings for a 2nd disc i have one on my sprint bike Yes Gaz E/F have twin disc fittings, Don't know what model woodentop is asking question about though. Old RD user has a twin disc set up on one of his 'E' model A/C's C/D don't . Mines a 'D'.
Post by woodentopp on Jan 29, 2013 20:30:09 GMT 1
Just though they would be a relative easy way to fit spoked wheels to my ypvs, (E/F) model wheels it is
Post by gazzatt2 on Jan 29, 2013 21:16:41 GMT 1
Just though they would be a relative easy way to fit spoked wheels to my ypvs, (E/F) model wheels it is they are very rare in the UK are they more common in Norway ?
Post by woodentopp on Jan 30, 2013 18:17:36 GMT 1
have no idea , I am originally from the UK but have been living here over 10 years. Am now trying all the local breakers as there is no real 2 stroke scenne over here. Hopefully I moght find a bargain.
