Post by tout on Jan 18, 2013 22:48:54 GMT 1
I HAVE PREVIOUSLY USED A PINK COLOURED LOCTITE PRODUCT WITH RELIABLE RESULTS........ALL GONE NOW
WHAT DO YOU RECOMMEND ?
REBUILDING THE MK1 125LC MOTOR SOON AND NEED TO BUY SOME GOO FOR THE JOB ....
T
Post by Trubrit on Jan 19, 2013 7:35:53 GMT 1
Post by garyt on Jan 19, 2013 11:13:46 GMT 1
i use bog std silicone never had a leak use it on exhaust aswell and its free ;D give us a bell if you want some tout
Post by billbott on Jan 19, 2013 11:47:55 GMT 1
i use bog std silicone never had a leak use it on exhaust aswell and its free ;D give us a bell if you want some tout Free? A fiver says he's rung you already!! ;D
Post by billy on Jan 19, 2013 15:48:43 GMT 1
I use Hylomar but I have no idea if it's good or not lol. It was recommended by an internet bike parts shop though and that's where I bought it from. EDIT: I have used high temp silicone sealant on the 350 before, and it lasts about 6 months, then it starts to separate from the aluminum around the crank area (and yes, I do clean the cases like mad before applying the sealant). I guess it's the petrol/oil mix that eventually gets it.
Post by Splodge on Jan 19, 2013 20:25:56 GMT 1
chez
Post by chez on Jan 21, 2013 20:39:44 GMT 1
i use bog std silicone never had a leak use it on exhaust aswell and its free ;D give us a bell if you want some tout Free? A fiver says he's rung you already!! ;D you beat me to it billbot you know hes tight too
Post by billbott on Jan 22, 2013 18:18:16 GMT 1
Free? A fiver says he's rung you already!! ;D you beat me to it billbot you know hes tight too ;D
Post by tout on Jan 22, 2013 22:23:07 GMT 1
Cheeky buggas.......I was phoning Gary before he had finished typing !
Always partial to a freebie..... just invested in some threebond, but count me in for some silicone please Gary...Cheers T
Post by garyt on Jan 22, 2013 22:44:20 GMT 1
got white brown black and clear let me know what you need
Post by mudguts on Feb 4, 2013 8:51:25 GMT 1
Post by yamaha52 on Feb 4, 2013 15:38:09 GMT 1
hylomar every time
Post by jollyjoiner on Feb 4, 2013 18:25:56 GMT 1
I've always use Hylomar Blue, i'll even be using it on the head on mine when I build it back together as i'll not be using a head gasket
Post by mudguts on Feb 4, 2013 19:28:01 GMT 1
threebond is what the manufactures use, they just have it repackaged, Yambond etc 1215 is there best gunge in a tube, no leaks on any of my bikes or my mates bikes, 1 tube will last you for years or until if dries out.
Post by bryan on Mar 20, 2013 15:09:46 GMT 1
Always used the Threebond and never had a problem so will stick with it. As its the correct thing for joining cases, why use something that isn't, not something that is quick and easy to put right if it fails.
K8DTG
Post by K8DTG on Apr 17, 2013 12:11:14 GMT 1
I have also got to "gloop" my crank case together and wondered if any of the Loctite products I currently have would be sufficient,
Loctite 5188 - Ideal for sealing all kinds of rigid metal flanges, especially aluminium flanges. Excellent in demanding applications, excellent chemical resistance, highly flexible. Superior adhesion, can tolerate slight oil contamination on the flange surface.
Loctite 510 - Ideal for use on rigid flanges where high temperature and chemical resistance is necessary
Loctite 5368 High proformance black silicone -65°C - 250°C
Loctite 5399 High Temp proformance red silicone -60°C - 270°C
