Post by Deleted on Dec 4, 2012 17:15:12 GMT 1
managed to find a thermostat for a 4lo 350lc on e bay, does anyone have a link to a microfiche so i can check part number? cheers mick and kaf
Post by midlifecrisisrd on Dec 4, 2012 17:25:19 GMT 1
Only got a UK pdf and it doesn't list a stat Steve
Post by Deleted on Dec 4, 2012 17:41:18 GMT 1
ah its a 29L part number so as far as i know its a jap spec part number could be wrong (waits to be bombarded saying i am wrong and a tit)
Post by 47x on Dec 4, 2012 18:27:29 GMT 1
your wrong.......and a tit!!!!lol(only joking chap!!!) ;D
Post by Deleted on Dec 4, 2012 18:31:23 GMT 1
lol ;D ;D
Post by 47x on Dec 4, 2012 18:32:36 GMT 1
oeb is the one to ask matey!
Post by Deleted on Dec 4, 2012 18:39:32 GMT 1
will send him a pm then
Post by 47x on Dec 4, 2012 18:41:29 GMT 1
(waits to be bombarded with pm from oeb saying IM WRONG....and A TIT!!!)lol
Post by Deleted on Dec 4, 2012 18:47:03 GMT 1
lol, know you can get a tz one but then housing needs to be machined
Post by Tone on Dec 4, 2012 19:31:22 GMT 1
If the part number is 29L-12411-00 this is the thermostat listed for the UK YPVS models Not the early 4LO ones as these had no stat fitted.
Post by Deleted on Dec 4, 2012 19:34:44 GMT 1
thats the one, so do we think it will fit?
Post by midlifecrisisrd on Dec 4, 2012 19:52:38 GMT 1
thats the one, so do we think it will fit? Might have one, would have to look. You can have it for nowt if I find one. Still think you would need the housing machined to fit. Steve
Post by Deleted on Dec 4, 2012 20:11:56 GMT 1
cheers mate fingers crossed ;D ;D
Post by steve h on Dec 4, 2012 21:55:07 GMT 1
If I have the same stat as you Mick, as Steve says, housing will need to be machined.
Post by Deleted on Dec 4, 2012 21:58:04 GMT 1
dont want to machine it
Post by midlifecrisisrd on Dec 4, 2012 22:07:13 GMT 1
cheers mate fingers crossed ;D ;D I'll have a look in the morning. Did the jap bikes not have stats??? Were the housings different? Steve
Post by Deleted on Dec 4, 2012 22:47:02 GMT 1
yeah jap bikes had stats, dont know about housing
Post by midlifecrisisrd on Dec 5, 2012 10:02:37 GMT 1
Just froze my ass off in garage, that's what I get for popping out in shorts and t shirt before I got dressed for work.
I have a YPVS stat that you are welcome to. It does not have the rubber sealing ring around it ( took it off to use on my 50 degree stat) but this may be ok for you if you are not wanting to machine the housing. I dare say you could use a flap wheel to reduce the outer diameter so it fits in the original housing and bond it in. It can't go anywhereso you just need to stop it rattling around.
Just remember to drill a 3 - 4 mm hole in it to allow some bypass circulation when it is shut.
pm me your address and I will pop it in the post if you want it.
Post by steve h on Dec 5, 2012 15:11:48 GMT 1
I wonder why the 4LO & 4L1 LCs never had a stat fitted in the first place? Other W/C 2ts have stats, so what makes these bikes different? Can't be down to a tropical climate here! where a stat would impede a certain amount of flow.
Post by Deleted on Dec 5, 2012 19:40:24 GMT 1
Just froze my ass off in garage, that's what I get for popping out in shorts and t shirt before I got dressed for work. I have a YPVS stat that you are welcome to. It does not have the rubber sealing ring around it ( took it off to use on my 50 degree stat) but this may be ok for you if you are not wanting to machine the housing. I dare say you could use a flap wheel to reduce the outer diameter so it fits in the original housing and bond it in. It can't go anywhereso you just need to stop it rattling around. CHEERS STEVE PM SENT Just remember to drill a 3 - 4 mm hole in it to allow some bypass circulation when it is shut. pm me your address and I will pop it in the post if you want it. Steve
Post by robin on Dec 5, 2012 20:29:51 GMT 1
If there is no rubber ring fitted to the stat, then it may fit in a standard housing, the outer diameter will fit nicely inside the gasket and the housing will clamp it down on both, it may need a (slightly thicker gasket). I machined the housing to fit my stat, took less than 5 minutes. I think there is a post here somewhere on the BB with pictures.
Robin
Post by midlifecrisisrd on Dec 5, 2012 21:54:23 GMT 1
2 gaskets should do it.
steve
Post by Deleted on Dec 5, 2012 22:44:06 GMT 1
Yeah a 4 or 5mm one
Post by robin on Dec 6, 2012 11:57:13 GMT 1
there is already a bypass hole / channel in the casting, to allow fluid to circulate around the stat, before it opens, but I did drill a hole "just in case"
Robin
