Post by loctite on Dec 1, 2012 17:13:21 GMT 1
im after a servo control unit for an f2 are thelc2/31k units the same guys also stator and magneto the same? cheers nigel
Post by 47x on Dec 1, 2012 17:19:20 GMT 1
servos are,as far as i know,stators are different tho,someone will surely come along and say wat is wat!!
Post by midlifecrisisrd on Dec 1, 2012 17:42:39 GMT 1
F2 and 31k controllers are different but can be made to work easily.
They are slightly different shaped ( F2 wedge shape, Lc2 is like a block with taper at one end.
F2/F1 and Lc2 all slightly different but mostly just the connector.
Early has a 3 way plug and later has 2 way and a single bullet. Plugs easily available from ebay and wiring colours all the same.
Lc2 5500 - 8600ish, F2 6000 - 10200 ( stupid it opens full after the red line )
Post by loctite on Dec 1, 2012 17:51:51 GMT 1
as usual always get the answers to my questions cheers chaps
Post by midlifecrisisrd on Dec 1, 2012 18:02:45 GMT 1
as usual always get the answers to my questions cheers chaps No worries, If you need the connector just search ebay for 2 way or 3 way motorcycle connector. Steve
Post by midlifecrisisrd on Dec 1, 2012 18:05:24 GMT 1
as usual always get the answers to my questions cheers chaps No worries, If you need the connector just search ebay for 2 way or 3 way motorcycle connector. Steve Forgot to say, 31k is better as it actually opens the valves at a usable rpm No point having a higher exhaust port if the cdi and PV controller don't make the most of it. Had a 1UA motor with 31k controller and cdi with abbey pipes and would rev to 10500 and still pulling strong, just was my max Steve
