Post by Taylormade on Nov 23, 2012 1:30:59 GMT 1
Hi can someone please answer a question on exhaust fitting? I assume not but do YPVS pipes fit an LC ? Surely they are different?
Post by ducatidave on Nov 23, 2012 9:24:02 GMT 1
Yes most can b fitted with a fresh hole in hangers
Post by ducatidave on Nov 23, 2012 9:26:29 GMT 1
Oh not 100% tho on standerd pipes off ypvs : (
Post by hooligan on Nov 23, 2012 17:03:01 GMT 1
If they don't fit 100% then they are extremely close. The last two LCs I've had both came with 31k pipes. It is pretty minor to make them fit.
Post by Taylormade on Nov 24, 2012 0:03:15 GMT 1
Thanks, this is good news, makes looking for pipes a bit easier
Post by rev1961 on Nov 24, 2012 3:50:24 GMT 1
Have a 31K set on a standard 4lo bike. The pipes run great but did need the hanging bracket to be extended along wth the bolt run in the revised bracket. As far as I remember some restricted their existin bracked alteration to a complete cut out of the bolt run. This however was not considered a safe approach.
Post by Delbert on Nov 24, 2012 9:52:53 GMT 1
I have also fitted 31k pipes to my 4lo , as you say easier to find & much cheaper ..
I had to file out the hanger bracket (as said ) also grind a half circle type shape out of the rear of the hanger or it touches the rear foot rest bolt & causes vibration as the pipe now sits further back ,, or you could just lobb a bit off the end of the bracket looks neater the other way as it keeps the original bracket shape
