Post by Taylormade on Nov 18, 2012 16:44:57 GMT 1
Hi all, so after allot of time and hunting i finally made a purchase and now own my first 350 LC ;D My first riding experience was great, I've owned GSXR 1100s Hayabusas etc and nothing was quite like jumping on an LC for the first time! However!! all was going great, went out for a ride stopped for a brew very happy with myself and really enjoyed the ride, made my way home to suddenly find the bike spluttering and having no power what so ever below 6000rpm it was almost to a point of having to slip the clutch to pull away, no power as the revs build no power then would only pull higher in the revs but didn't feel right. Any help would be greatly appreciated, I'm excited still but a little deflated now.
Post by Taylormade on Nov 18, 2012 17:01:11 GMT 1
Yes, running 4LO Barrels 4LO-1 carbs, its a 1983, standard pipes etc
Post by midlifecrisisrd on Nov 18, 2012 17:04:03 GMT 1
Sounds like fueling. Blocked pilot, stuck float or something like that or even reeds
If it was running fine before it will hopefully be a simple thing like that, especially if it had been laid up or not used often
Post by Taylormade on Nov 18, 2012 17:08:37 GMT 1
Yeah its not been used that often, felt like Major fuel starvation to me! You will have to forgive my ignorance as I've never owned an LC before what are the reeds? I've heard of them but am unsure what they do....?
Post by midlifecrisisrd on Nov 18, 2012 17:13:45 GMT 1
Yeah its not been used that often, felt like Major fuel starvation to me! You will have to forgive my ignorance as I've never owned an LC before what are the reeds? I've heard of them but am unsure what they do....? They are between the carb rubbers and the barrel. They are petals that open to let the fuel in but close to stop the the back pressure from the down stroke blowing back through the carb. Have a look at the inside of the tank, if it is rusty it can block the fuel to the carbs or if it gets into the carbs will block the jets. Steve
Post by Taylormade on Nov 18, 2012 17:22:14 GMT 1
Inside the tank is mint! and i mean mint, was surprised how clean it was as every LC i have viewed had rust in the very bottom.
Not saying there isn't any crap in the tank but no rust or at least so minimal u would have to look hard.
It was running fine before gave it the big one off the roundabout then all of a sudden sputtering so crap in the carbs could well be the cause.
Do the reeds suddenly fail?? are they easy to get hold of?
Post by midlifecrisisrd on Nov 18, 2012 17:28:42 GMT 1
petals can fail, not so much if standard metal ones are used but fibre ones can break.
It's either that or something else like crank seal or ring failure.
As said get a manual and start at carbs, also look for air leaks as loose bolts or split intake rubbers will much up the mixture.
Post by Taylormade on Nov 18, 2012 20:38:22 GMT 1
Thanks, will start at carbs, this will be a whole new learning curve for me.......
Post by 2cl on Nov 18, 2012 21:54:23 GMT 1
Taylor, sounds like you will be doing abit of reading, where in Essex are you.
Post by Taylormade on Nov 18, 2012 22:06:05 GMT 1
Yep reading on the agenda ! I'm near Epping whys that mate?
Post by copper99 on Nov 18, 2012 23:23:14 GMT 1
welcome mate, hope you get it all sorted soon enough...and pop some pics up when you can.
Post by Taylormade on Nov 19, 2012 0:13:27 GMT 1
Yeah thanks will do, that will probably be the next challenge as by the looks of things i will have to open a photo-bucket account (no probs) and the Mac I'm using is all new to me too..........
Post by bubba on Nov 19, 2012 20:13:09 GMT 1
hello taylor and welcome along great to here you have bought a lc 8-)hope you get it sorted mate you will be a dab hand at taken it to bits and putting back together in no time!
