Post by Delbert on Nov 4, 2012 22:51:32 GMT 1
We are all a bit paranoid that our motors are being fed enough oil !!! Plenty of threads about premix ratios. So what about the the autolube boys As a rough guide any one know approx how many miles they get from a litre of 2 stroke ??
Post by marsbar350 on Nov 4, 2012 23:02:30 GMT 1
my 350 does 200 miles per litre of oil
Post by Deleted on Nov 4, 2012 23:59:18 GMT 1
Yeah about same as mars bar,
Post by Deleted on Nov 5, 2012 0:00:52 GMT 1
id say mines similar to yours marsbar, its set to be run a bit of extra oil , arrow set mine up.
Post by marsbar350 on Nov 5, 2012 0:10:40 GMT 1
he did mine aswell setting on mine is .28mm its having new seals fitted at the moment ;D
Post by Deleted on Nov 5, 2012 0:15:19 GMT 1
mines set at .31, he told me to sand down a shim a little if i wanted but ive decided to leave it like it is, must be nearly bed time over there, ive just gotten the kids off to school, cheers
Post by marsbar350 on Nov 5, 2012 0:18:14 GMT 1
when you build aeroplanes for a living.being conservative helps.for the sake of a few drops of oil and poss seizure.like watchin the missus sup white wine ;D
Post by Delbert on Nov 5, 2012 8:17:16 GMT 1
Very true marsbar ;D Im up to 90 miles so far so will be interesting to see if im around the same
Post by lovelydog on Nov 5, 2012 8:29:06 GMT 1
Since fitting microns I've used bigger main jets and adjusted my autolube pump to deliver more oil,not sure what I'm getting out of a litre yet,will try to work it out.
Post by midlifecrisisrd on Nov 5, 2012 9:17:10 GMT 1
I must be in the 150 to 200 miles range but deliberately running higher oil and state of tune means lower mpg
