Post by scoobytoo on Nov 3, 2012 22:17:59 GMT 1
Can anyone recommend a good belly pan fitting kit with rubber insets on clamps or "p" clips. The original fittings with my pan will scratch the crap out of my frame. I know Norbo does a kit but look just like metal clamps only? Pics would be handy please
robw
Post by robw on Nov 3, 2012 22:20:36 GMT 1
Hi, I used rubber p clips to mount my belly pan. I only used 3 as one was a right pain to get acces to. Rob
Post by scoobytoo on Nov 3, 2012 22:24:18 GMT 1
Cheers rob, if I could get some with captive nuts they may be easier to fit ?
Post by oldelsieboy on Nov 3, 2012 22:42:06 GMT 1
I used 4 rubber lined P clips to fit mine, found it best to fit this one first with the pan tilted to the side. OEB
Post by scoobytoo on Nov 3, 2012 22:48:48 GMT 1
What size are oeb ?
Post by oldelsieboy on Nov 4, 2012 9:02:00 GMT 1
There is a clue in the photo OEB
Post by lovelydog on Nov 4, 2012 9:36:41 GMT 1
I fitted mine with the kit from Norbo. That right hand one was an arse to fit,my son ended up making a bracket out of a strip of alluminium and bending it to a 'P' shape,we lined the brackets with strips of double sided sticky pads that are like foam 2mm thick. This was fitting the kit over old small can microns,it was fiddly to fit and did have to fit the right side first then tighten everything up after.
Post by scoobytoo on Nov 4, 2012 11:13:18 GMT 1
Oeb, wasn't sure what you meant as I'm looking at it on my ihpone, but just zoomed in
Post by alext on Nov 4, 2012 21:54:15 GMT 1
i didnt put the back 2 clips on mine. (I actually couldnt get the one pictured above to fit at all)
I fitted one of the u-clanps to the crossmember at the mainstand and made a bracket to mount down to the middle of the belly-pan, and it bolts up to that - unfortunately I did this after I painted it, otherwise I couldve filled the two back holes in.
its dead easy to fit the 'pan, as this back mount holds it enough in place while you fit the front two mounts.
Post by scoobytoo on Nov 6, 2012 21:23:08 GMT 1
I've ordered 25mm rubber lined stainless p clips. I've also sourced via our wonderful auction site coutersunk white nylon screws/bolts and washers etc to blend in with the pan so I'll put a picture up when they all arrive.
Stick
Post by Stick on Nov 8, 2012 11:43:26 GMT 1
Where did you source the P clips dude.
Post by scoobytoo on Nov 8, 2012 14:33:36 GMT 1
eBay m8, 100's of them just search the size you need
Post by scoobytoo on Nov 8, 2012 14:34:03 GMT 1
Part 2 arrived today
Post by elsie1411 on Nov 9, 2012 17:35:18 GMT 1
scoob if you have the original kit they work really well and mine hasnt marked the frame at all. if youre worried just wrap some insulating tape around the frame first
Post by scoobytoo on Nov 9, 2012 20:52:40 GMT 1
Cheers for that Elsie. I've bought nylon countersunk screws and washers etc with rubber lined stainless p clips. Wasn't keen on the metal finish against the white paint. Going to try and fit the belly pan Tomoz so ill put some photos up.
Post by steve h on Nov 9, 2012 22:11:15 GMT 1
scoob if you have the original kit they work really well and mine hasnt marked the frame at all. if youre worried just wrap some insulating tape around the frame first Good tip and it works well!
Post by scoobytoo on Nov 11, 2012 13:25:22 GMT 1
Post by flames on Nov 11, 2012 17:47:58 GMT 1
that looks mitey fine dude.great job.
Stick
Post by Stick on Nov 29, 2012 14:34:03 GMT 1
Just got some 25mm rubber lined P clips for mine, will report back with some photo's on how I got it to fit if possible. Also Wickes sell small packets of galvanised domed nuts cheap in 6 or 8mm sizes, so will see what they look like.
