Post by pouchy750 on Nov 1, 2012 20:58:43 GMT 1
Can anybody confirm that to remove the gear lever shaft you don't have to split the case.
You can remove it by removing the clutch basket & then extracting it from that side of the engine?
Thanks
chez
Post by chez on Nov 1, 2012 21:02:02 GMT 1
just remove the clutch basket
Post by lcrider on Nov 1, 2012 23:00:26 GMT 1
as above its a simple job just taks some time to do thats all .
Post by rich on Nov 2, 2012 20:37:46 GMT 1
Yep but removing the clutch basket is a pain - drain oil, drain coolant, you also have to remove the clutch centre nut so you'll need some sort of holding tool. Also a good idea to get a new tab washer as well. As said, not hard but just a pain
db8888
Post by db8888 on Nov 2, 2012 21:28:50 GMT 1
Silly question why are you taking out if its to replace the seal you should be ok with it in place
