Post by efftwo on Oct 26, 2012 18:59:29 GMT 1
When I push my bike backwards the back brake rubs and it is quite a racket. What's the cause/fix? Caliper has new pistons and seals but it did this prior.
Post by marddy on Oct 27, 2012 12:26:47 GMT 1
If all the parts in the rear caliper is new, then MC could be the reason. Try flushing out the the oil and add some new.
Post by Shytalk on Oct 28, 2012 10:11:58 GMT 1
Depends on whether you thoroughly cleaned out the seal grooves before installing new seals. Also some do, some don't use red rubber grease on assembly. Only when pushing backwards ?? Caliper bracket twisted perhaps?
