Post by efftwo on Oct 23, 2012 23:35:25 GMT 1
Putting microns on a 4CE with power jet carbs. To increase the jetting do you put in bigger power jets or bigger main jets? Currently on 185 mains with 55 power jets. Standard air filter and tune.
Post by Norbo on Oct 24, 2012 8:14:32 GMT 1
Its only the main jet you need to change id pop a 200 in them and see how it runs remember to turn up the oil pump a little when up jetting and allways do a plug chop after and carb change .
Post by midlifecrisisrd on Oct 24, 2012 8:15:02 GMT 1
Up the mains
Both operate on full throttle so add together, think you would struggle to get bigger power jets
