Post by spencerd on Oct 21, 2012 18:37:16 GMT 1
Guide setting for those wishing to run pod filters:
Foam cranked pod filters Repacked Allspeed exhausts 0.25 oversize bores B9ES (non resisted) plugs Standard setting oil pump Gravity fuel feed Standard 26mm PJ Mikuni carbs Standard PJ's Standard slides Standard needles with clip in standard location (2nd from top) Standard (but replaced) needle/petrol valves 30 pilot jets (standard are 27.5) 230 main jets (standard are 185) Air screws 1 1/2 turns out
Mine runs & ticks over sweet!!
I would have posted this in the carb section but could not see the 'new thread' option!
Post by dusty350 on Oct 22, 2012 7:19:18 GMT 1
Hi, That's usefull info thanks. I have virtually the same set up, stainless large can gibson allspeeds, Norbo's foam pod filters and everything else is standard F2, powerjet carbs etc. I did buy some 31k carbs to make life easier when I fire up the bike for the first time, but they were knackered so I sent them back. I had even considered a Y boot set up, but there seems to be very little info on their use in the UK. Where did you get your jets from ?
Dusty
Post by spencerd on Oct 22, 2012 11:54:41 GMT 1
Pilot jets from YAMBITS main jets from EBAY!!
Post by dusty350 on Oct 22, 2012 17:37:48 GMT 1
Cheers Dusty
