Post by pouchy750 on Oct 20, 2012 0:13:54 GMT 1
I have a small leak of oil from the gearbox when the bike is on the side stand.
Is it possible to replace the gear lever shaft oil seal without splitting the cases?
Thanks
Post by midlifecrisisrd on Oct 20, 2012 11:25:43 GMT 1
Yes but make sure the shaft is not worn and grooved as new seal will be the same.
Simply pry out with a driver then tape over the splines before slipping the new one over.
Also make sure it is not coming from the neutral switch cover plate as these crack.
