Post by pouchy750 on Oct 14, 2012 21:58:21 GMT 1
The rotors on my F2 appear to be worn.
The manual says the discs should be 5 mm thick, but measuring the thickest (outer) part of the disc, they only measure at 4.5mm
I've measured the worn part of the disc where the pads rub against & it is only 3.8mm. Is this acceptable?
Are the standard discs flat the whole way across & mine are worn from use?
Thanks
Post by steve h on Oct 14, 2012 22:44:43 GMT 1
I think the service limit is 4.5mm (where the pads grip) so I think they are shot. I wouldn't risk anything in the brake dept. Disc should be flat the whole way accros when new.
Post by steve h on Oct 14, 2012 22:46:07 GMT 1
Sorry "across"!!!!
Post by fatfastroger on Oct 15, 2012 20:27:13 GMT 1
If they are that bad then you must be feeling this at the lever. You should replace the pads when you fit new rotors
