Post by fatfredfaefife on Oct 11, 2012 12:50:30 GMT 1
Hi All Nearing the end of my rebuild on my 31k, so bought a set of microns from someone on this site who said microns would fit straight on to your 31k. I am now having a bit of a dilemma on this as they don’t seam to fit that well, no place to put the springs and a bit of a gap between the exhaust and head. Do I need a different fitment for a 31k? Any suggestions welcome. Thanks in advance.
Post by midlifecrisisrd on Oct 11, 2012 15:21:17 GMT 1
Post by mellow on Oct 11, 2012 16:43:13 GMT 1
mine dont have hoops on the flanges. i just bought a set of the things that fit under the stud nut then just hook the springs into them
Post by fatfredfaefife on Oct 11, 2012 18:40:16 GMT 1
Thanks Steve and Mellow...great advise and looks the flanges will solve it, I did put in the copper gaskets with plenty of heat resistant liquid gasket.
Post by fatfredfaefife on Oct 11, 2012 18:42:01 GMT 1
Sorry Steve don't need any paint work, had all mine done by norbo's mate.
Post by midlifecrisisrd on Oct 11, 2012 20:23:49 GMT 1
Sorry Steve don't need any paint work, had all mine done by norbo's mate. No worries, picking up mine from Norbo tomorrow but got spares now ;D Steve
lcbob
Post by lcbob on Oct 11, 2012 20:28:08 GMT 1
The gap you have there is virtually the same as my 31k. As midlifecrisis says,as long as you use the gasket you will get a good seal. Mine uses the washer type flange placed under the nut for the springs.
Post by peterlc2 on Oct 11, 2012 20:49:22 GMT 1
It looks like your flanges are welded on to the pipes, if so, you don't need springs as they pull the pipes closer to the flange for a better seal.
Post by Bozzy on Oct 11, 2012 21:30:06 GMT 1
My nikons and new set of kennys pipes are exactly the same on k31 with the gap.
Post by lovelydog on Oct 11, 2012 21:58:30 GMT 1
Put Microns on an lc recently with the same big gap. Used just the round copper type exhaust gasket and it's fine,I haven't got the springs attached as it locked up nice and snug and doesn't leak.
Post by fatfredfaefife on Oct 12, 2012 9:28:28 GMT 1
Thanks to all who replied, this has really helped me out.
Post by pepsisteve on Oct 13, 2012 20:32:02 GMT 1
as above, they look like the pipes have been welded to the flanges so no springs needed
Post by mikee on Oct 13, 2012 22:33:52 GMT 1
Drill 2. 3 mm holes in the flange at about 11/1 o,clock fit the springs thru them Or get a flange bolt mount , a 10mm spacer in between the barell and pipe flange will help
Post by midlifecrisisrd on Oct 13, 2012 23:21:15 GMT 1
as above, they look like the pipes have been welded to the flanges so no springs needed The microns have a double skinned header so the weld you see is where the outer skin is welded on. Flange goes in between the two skins, joint is actually where you see the grey sealant so springs are required. Steve
