Post by marsbar350 on Oct 6, 2012 19:51:59 GMT 1
took a spare set of forks round to butch last night.the extra pair of hands come in real handy ;D the oil was like a breast fed babys shit one spring is 15mm longer than the other also in the forks were these beauties
Post by marsbar350 on Oct 6, 2012 23:27:35 GMT 1
can anyone tellme why one spring id 15mm longer than the other? what are the nylon inserts for.obviously homemade with a washer stuck on
Post by winnerevo1 on Oct 7, 2012 1:23:55 GMT 1
The different length springs are anybodys guess, but if neither has a bit broken off then probably what they found lying around plus they look a bit thick for standard LC ones although not completely sure? The nylon spacers were probably to preload the springs or they both might've too short to start with.
