m1ke
Post by m1ke on Oct 6, 2012 18:46:31 GMT 1
m1ke
Post by m1ke on Oct 6, 2012 19:05:00 GMT 1
So the plan now the bike is home goes like this. - Strip the bike completely inspecting what needs to be repaired/refurbed/replaced
- Get Frame, Swingarm, Wheels and all the other little bits that need it powdercoated
- Find a good fuel tank, the current one is a bit too rusted for my liking even with a tank lining
- Top end engine strip and clean/inspection. (What I find will direct what happens here....)
- Buy a few shiny goodies, braided brake lines, silicone coolant hoses, billet water pump. I'm sure this list will grow......
- Plus I need to decide what to do with the bodywork, at the moment it is reasonable and original but not perfect. I'd like perfect, but then it's likely to get worn in use anyway so I may just give it a good polish for now....
- Rebuild it all in time for spring so it can come out in all it's glory.
I will keep the updates coming as I move along....
Post by marsbar350 on Oct 6, 2012 19:43:08 GMT 1
welcome in mike looks a pretty complete f2 you have got plenty of info you need on here especially from mr mellow the f2 guru
m1ke
Post by m1ke on Oct 6, 2012 19:45:41 GMT 1
Yep, It seems very complete and generally unmolested which is what I like. Most of the screws etc look like they have never been touched which Is a good sign as too many people seem to like to use the wrong size screwdriver and wreck things.....
Post by kennyroberts on Oct 6, 2012 20:36:21 GMT 1
Very nice and unmolested.........shame im molesting mine....( did i say that outloud) Good luck with it
m1ke
Post by m1ke on Oct 6, 2012 20:48:13 GMT 1
It does seem tempting to molest it, but maybe I need another that is less standard for that.....
Post by marsbar350 on Oct 6, 2012 20:53:31 GMT 1
mike have a look at mellows f2 very nice rebuild should be tho it only comes out at norbos bbq ;D
m1ke
Post by m1ke on Oct 7, 2012 19:27:31 GMT 1
So made a bit of progress today, bike fully stripped to just a frame. Thought I was going to have issues with a few rusty bolts but only had the two rear mudguard bolts shear off, but managed to get the rest of the bolt out with some blowtorch and mole grip action once the plastic was out of the way. Here's how it is now.... Found a few things that need a bit of work on them, the bushes in the swingarm for the link arms are very worn. Possibly the link arms too will have to get measuring and see which it is though..... The headlight/mirror/fairing bracket needs a bit of welding as it seems a mirror has been knocked off in the past. The sidestand could do with having a new pad welding to the bottom too. Does anyone know if you can still get new main stand bolts? The powervalve joining piece is on there tightly at the moment but the screws are a bit ruined. Other than that the bike seems to be in great shape and I was very suprised that all the bolts came out so easily without stripping or snapping. So far it has been a pleasure to work on
Post by scott on Oct 7, 2012 21:43:20 GMT 1
welcome to the site m8,try norbo m8 i know he does some st/st bolts for the centre stand but dunno about gen one's
Post by mellow on Oct 7, 2012 21:56:14 GMT 1
Hi mate. Bike looks ok,apart from mirrors missing I would imagine the stand bolts are still available.I bought heaps of genuine new stuff when doing mine. Can email you a parts fiche so you can go armed with part numbers
m1ke
Post by m1ke on Oct 7, 2012 22:07:34 GMT 1
Thanks for the parts fiche offer Mellow, already found one on the web. Does anyone know of a Genuine Yamaha service manual in english?
Post by twosmokinbarells on Oct 10, 2012 18:26:48 GMT 1
yes main stand bolts are still a available . i brought some a couple of months back .
m1ke
Post by m1ke on Oct 10, 2012 19:31:27 GMT 1
Thanks for that, good to know what is still available. Need to start the process of cleaning/sorting now. Frame, swingarm, wheels and brackets etc will all be going off to be powdercoated.
Engine will come apart for inspection once my clutch and flywheel tools arrive.
Post by kennyroberts on Oct 10, 2012 20:21:02 GMT 1
Its all moving too quickly....i feel dizzy.....i prefer my pace.....an item a month...lol
m1ke
Post by m1ke on Oct 10, 2012 22:40:12 GMT 1
Its all moving too quickly....i feel dizzy.....i prefer my pace.....an item a month...lol It will slow down a bit for a few weeks now. Various other engagements are stealing my spare time..... I don't want it finished too early or it will tempt me to get it on the road whilst it is still winter....
m1ke
Post by m1ke on Oct 27, 2012 10:50:44 GMT 1
Frame, swingarm and various other bits have been dropped off at redditch shotblasting this morning to get powdercoated . Will pull the engine apart this week and decide what needs doing. My wallet says keep it standard, my heart says get some porting and a rebore. Heart will probably win..... Heart also says 28mm carbs, tsa road pipes and a zeeltronic...... That might be a longer term heart winning over head... Does anyone know if yamaha still sell the foam surrounds for the clocks?
Post by kennyroberts on Oct 27, 2012 17:18:47 GMT 1
Dont think so .mine is shot and was thinking of making a batch.....just need to get around to cncing a mould for some polyeurothane foam.. Otherwise some black foam sheet would be ok ....dont forget to post pics of the freshly coated bike bits!!!!
m1ke
Post by m1ke on Oct 27, 2012 17:42:10 GMT 1
If you do make a batch let me know...
m1ke
Post by m1ke on Nov 7, 2012 22:13:33 GMT 1
A month in and the engine has been stripped. Crank needs a rebuild/exchange as the main bearings are all a bit rumbly, powervalve joint needs replacing. It's going to get a rebore while I am in there as although it is not worn out I want it to be good for a long time.... No one ever said this was going to be cheap..... No photos because everyone knows what a stripped ypvs looks like . I will post more pics as the build goes on...
Post by kennyroberts on Nov 8, 2012 0:10:39 GMT 1
And ill be looking at them!
mervin
Post by mervin on Nov 16, 2012 13:58:33 GMT 1
Its all moving too quickly....i feel dizzy.....i prefer my pace.....an item a month...lol runs in the family , i am his Dad and did an aircooled 250 in about 6 weeks once
m1ke
Post by m1ke on Nov 17, 2012 12:07:33 GMT 1
;D Got the powdercoating back today, have left most of the other bits that I have had done wrapped up until I need them.
m1ke
Post by m1ke on Nov 18, 2012 23:33:12 GMT 1
Had a fairly productive weekend, have got the engine cases and head cleaned of all the dirt and road grime. And have got the pistons out from the front calipers. The rear caliper is proving to be a little more troublesome.... One piston is on the move but I can't get the second one to move yet.
Ordered some paint for the head/top case and calipers. But have the fun of paint stripping to go through first. And I couldn't find any shop in the area open on a sunday that sells much other than overpriced not so good nitromors...
m1ke
Post by m1ke on Dec 5, 2012 17:31:56 GMT 1
Went to Norbo's house of goodies today and came back with quite a few things to help the rebuild carry on. Also got my powervalve's and bushes back from getting new bronze bushes put in, big thanks to Mart13 from the TDR club for this.
All the brake calipers are apart now, and have bought some "trade use only" paint stripper from ebay. Tested it on one caliper half, this stuff is better than Nitromors ever was.... But it is now very cold outside, and in the garage.
Getting there slowly with all the parts I need for the re-build.
Post by Splodge on Dec 27, 2012 17:49:42 GMT 1
Good work chap keep it up Do you have a link for that "trade use only" paint stripper from ebay? as l'm sure a few of us on here could do with some ta
m1ke
Post by m1ke on Dec 27, 2012 17:56:52 GMT 1
Post by The Pirate on Dec 27, 2012 18:24:57 GMT 1
wow them carbs look well clean, how did you say you did it?? ultrasonic,, can I have a bit more info please ;D ;D
m1ke
Post by m1ke on Dec 27, 2012 18:34:34 GMT 1
Post by Splodge on Dec 27, 2012 19:36:25 GMT 1
Cheers for that l have been after sone decent stuff since they ruined the origional Nitromorse
