Post by marsbar350 on Oct 1, 2012 21:08:09 GMT 1
hi guys took my stator side casing off today and found there wasnt a bushwhere the gearshaft comes through.i have a spare with one in.tried to fit and wouldnt go in did some casings have them and some not? heres a pic of my spare casing with the steel insert
Post by steve h on Oct 1, 2012 21:42:23 GMT 1
I dont think they had them. Nobo sells the bushes and you have to ream the casing to fit them.
Post by winnerevo1 on Oct 1, 2012 21:56:42 GMT 1
If you are talking about an LC/4L0 and mean the actual cover itself then yes, there are two types.
One with just a plain hole in the cover and the other with a steel sleeve inserted, there should also be a small seal fitted in the outside of the cover.
Post by winnerevo1 on Oct 2, 2012 18:16:29 GMT 1
Yes, that's what I thought you meant and yes there are two types. The other type doesn't have the steel sleeve fitted, it just has the correct sized plain hole bored straight in the case.
Post by marsbar350 on Oct 2, 2012 18:29:07 GMT 1
thanks for that the one on me bike is wearng with no sleeve goin to change the casing.
