Post by hardhatharry on Sept 22, 2012 19:24:41 GMT 1
Hi y'all
I am finishing an engine build and fitting the paper gasket on the clutch /gearbox side on a 31K engine.
I have previously fitted a pattern one but it leaked, I cleaned up the faces and greased the gasket but I dont know if it leaked due to poor preparation, dodgy cases or incorrect fit.
I now have a proper Yam one (£16 ouch!) and I dont want this too leak so I'm after advice to ensure I'm not forking out again.
I have cleaned up the face again using methalated spirits as per the manual and when I run my finger round the faces I cant feel any raised bits.
Do I just put the gasket on and tighten the screws?
Grease the gasket, fit and screw?
Put a thin smear of generic seal (clear type looks a bit like silicone) on either face prior to fitting gasket, fit and screw?
Cheers for any advice!!
Post by Shytalk on Sept 22, 2012 19:34:36 GMT 1
In theory dry will be fine, you can put a smear of grease on it if you want to re-use it next time, don't put silicone sealant on it - as it will be destroyed if / when you take the cover off next time. If it still leaks then its time for the sealant.
Post by 47x on Sept 22, 2012 20:28:37 GMT 1
use the gasket dry,DONT use sealant!!!
higgsy
Post by higgsy on Sept 25, 2012 4:44:32 GMT 1
I always lightly grease mine, pattern or genuine, never had a leak yet. It's very easy to get the gasket misaligned when putting it on, greasing it holds it in position and means you can use it again
Post by bigal1 on Sept 25, 2012 8:19:32 GMT 1
i allways grease new gaskets and have done for over 20 years and never had a problem
Post by theodoric on Sept 25, 2012 12:38:24 GMT 1
For me it's a drop of grese to hold it insitu but other than that dry fit everytime.
Post by bigal1 on Sept 25, 2012 13:13:06 GMT 1
the only problem using silicone it can go inside your engine a gob things up grease just melts into the oil ... a old Porsche mechanic told me about using grease IV used it ever since if you clean the 2 faces were the gasket goes it should never leak
Post by Bozzy on Sept 25, 2012 13:56:03 GMT 1
I used silicon on both faces and it has not leaked.
My understanding is the the silicon breaks down in oil always used silicon on every gasket and never had a leak or problems.
But obviously when removing cases etc it does rip the seal after time.
Post by steve h on Sept 25, 2012 15:37:30 GMT 1
Grease, same as bigal1.
Post by rdstars on Sept 25, 2012 19:33:41 GMT 1
I've never had a gasket leak, even a patten head gasket. Take time cleaning the surface, if it looks dirty then clean some more. I always use some good quality Silicone, nothing like a spot on seal so why take chances.
Post by billy on Sept 25, 2012 21:42:38 GMT 1
I always use a bit of grease on the gasket and I've never had any problems with it. I imagine it'll give a slightly better seal (?), but the grease is mainly not for sealing purposes, but rather so that it'll pop off easier next time so I don't have to replace them all the time.
Post by billy on Sept 25, 2012 21:45:43 GMT 1
Btw, when it comes to head gaskets though, I DO NOT use any grease. I don't know if you COULD do it with good results, but me, I don't do it. I believe modern head gaskets (the ones in metal) should have a dry mating surface. Each to their own though, some use sealant etc and don't have any problems so...
