Post by wayneh4l1 on Sept 21, 2012 11:14:18 GMT 1
1st time on here, just purchased an 81 4L0/4L1 LC. Looking for a bit of help, if anybody out there can Advise. When in Neutral both red & green lights come on, when in gear they both go out ? Its as if the oil light is working the same as the neutral light. Is this correct or is it just a bad earth somewhere.
Is there anybody else from the Leeds Area into LC,s ?
Wayne.H.
Post by Deleted on Sept 21, 2012 12:23:32 GMT 1
1st time on here, just purchased an 81 4L0/4L1 LC. Looking for a bit of help, if anybody out there can Advise. When in Neutral both red & green lights come on, when in gear they both go out ? Its as if the oil light is working the same as the neutral light. Is this correct or is it just a bad earth somewhere. Is there anybody else from the Leeds Area into LC,s ? Wayne.H. when the bike has the ignition on and is in neutal with enough oil in the autolube then both oil and neutral light will be on, if no oil light then oil level is low, also if oil light comes on when you are riding the bike then you need some oil in the autolube
Post by Deleted on Sept 21, 2012 12:24:47 GMT 1
red light is oil green is neutral wakefield here
Post by stanlc7189 on Sept 22, 2012 23:51:48 GMT 1
Both red and green lights should come on and off together, unless oil level is low then the red light will stay on even after the green has gone out
scoobysal
If it hurts, you know ya made it.
Post by scoobysal on Sept 23, 2012 12:21:10 GMT 1
I had an odd time with my oil light yesterday. took it out to get used to the bike and the oil light came on whilst giving it a bit of a blast. Stopped and checked it and there was plenty in. I dont recall it coming on so early in the past.
Post by Deleted on Sept 23, 2012 23:24:02 GMT 1
scooby mine comes on under heavy braking its when it is on all the time that it's time to worry
Post by Norbo on Sept 24, 2012 9:53:07 GMT 1
welcome to the site. sounds ok to to me evey thing is working fine.
