jets
Sept 20, 2012 9:26:25 GMT 1
Post by ozzy on Sept 20, 2012 9:26:25 GMT 1
10w carb micron standard air box whats jet size best is...
10w carb allspeed standard air box whats best size jet...
10w carb k/n all speed best jet size is...
needle on 4th from top
no pre mix just pump fitted.
cheers oz
jets
Sept 20, 2012 13:43:15 GMT 1
Post by Norbo on Sept 20, 2012 13:43:15 GMT 1
10w carb micron standard air box whats jet size best is...220
10w carb allspeed standard air box whats best size jet...210
10w carb k/n all speed best jet size is...220
jets
Sept 20, 2012 13:44:02 GMT 1
Post by Norbo on Sept 20, 2012 13:44:02 GMT 1
and ajust up the oil pump after you up jet at least 1 full turn and allways do aplug chop befor you start propper riding to make sure you are getting anough oil threw.
jets
Sept 20, 2012 14:49:02 GMT 1
Post by Nismosis on Sept 20, 2012 14:49:02 GMT 1
This is an interesting thread. I've been told to go up 2 - 3 jet sizes when using a micron can. my bike has a 10W carb and standard airbox. the standard 10W main jet is a 155 so I'm looking to use either a 165 or a 170.
I know every engine is different and responds differently, but the difference between a 170 and a 220 is a lot. Now I'm confused.
When I get my Micron fitted I was going to use a 170 main and see how I get on, now I feel like I would be seriously underfuelling it. I'd hate to seize it as it's just had a rebore and a new piston/rings.
jackup
Of all the things I've lost I miss my mind the most
jets
Sept 20, 2012 15:47:29 GMT 1
Post by jackup on Sept 20, 2012 15:47:29 GMT 1
I think norbo has quoted for 12a carb
jets
Sept 20, 2012 16:31:25 GMT 1
Post by mellow on Sept 20, 2012 16:31:25 GMT 1
im on standard airbox,mk3 carb (standard jet 195) & nikon pipe & got a 220 in and it aint blown up yet
jets
Sept 21, 2012 8:49:34 GMT 1
Post by Norbo on Sept 21, 2012 8:49:34 GMT 1
I think norbo has quoted for 12a carb Yes i did sorry not paying atenshon as usuel sorry it should say 10w carb micron standard air box whats jet size best is...180 10w carb allspeed standard air box whats best size jet...170 10w carb k/n all speed best jet size is...180
jets
Sept 21, 2012 9:08:30 GMT 1
Post by ozzy on Sept 21, 2012 9:08:30 GMT 1
cheers norbz..
jets
Sept 21, 2012 10:49:50 GMT 1
Post by Nismosis on Sept 21, 2012 10:49:50 GMT 1
jets
Sept 22, 2012 14:27:24 GMT 1
Post by mudguts on Sept 22, 2012 14:27:24 GMT 1
What about a RD MK 3 with 2hk tzr carb standard jet is 180, standard box and Allspeed fat can, im trying a 200 to start with do you think thats about right? needle 1 up from bottom (raised by 1 notch), running oil pump 1mm past the dot richer .
jets
Sept 22, 2012 18:36:04 GMT 1
Post by martinharvey on Sept 22, 2012 18:36:04 GMT 1
any ideas 12a carb,2mm oversize piston.standard exhaust with washer cut out at the front of pipe. got a 230 jet in is this to b ig? ?
jets
Sept 22, 2012 23:19:57 GMT 1
Post by mellow on Sept 22, 2012 23:19:57 GMT 1
i would say so
jets
Sept 29, 2012 16:26:59 GMT 1
Post by LC_BOTT on Sept 29, 2012 16:26:59 GMT 1
What are the standard jet sizes please? just pulled out a 12A carb and the jet is a 210, is this ok for a standard set-up? or has it been jetted for an exhaust and then been removed?
jets
Sept 29, 2012 18:13:40 GMT 1
Post by gerumgoin on Sept 29, 2012 18:13:40 GMT 1
Im going to go with standed 10 w pipe and standard airbox,Just had a look at the 10w carb im going to fit, and main is a 190 anygood to run it like this?
jets
Sept 29, 2012 19:11:15 GMT 1
Post by broughton5 on Sept 29, 2012 19:11:15 GMT 1
12a standard main jet is 195. 10w standard main jet is 155. i have a 10v carb fitted it had a 190 main in and ran like crap struggling to get in the band, now got a 165 in and runs fine, done 2,000 miles since rebuild with no issues at all and seems to run quite cool. sorry nearly forgot also as a micron fitted.
jets
Sept 29, 2012 19:33:01 GMT 1
Post by gerumgoin on Sept 29, 2012 19:33:01 GMT 1
so for my bike to run smooth as silk with standed 10w zorst and carb i need to change jet to 155. ;D cheers
