Post by daglad on Sept 19, 2012 19:20:11 GMT 1
i am a little confused i need front wheel bearings for my 31K but my problrm is on his norbships web page there are 3 different bearings being 6301, 6302 and 6202 which ones do i need?
Post by oldelsieboy on Sept 19, 2012 19:41:45 GMT 1
i am a little confused i need front wheel bearings for my 31K but my problrm is on his norbships web page there are 3 different bearings being 6301, 6302 and 6202 which ones do i need? If you check out the parts fiche it will confirm which ones you require You will also notice that the 5th, 6th, 7th & 8th numbers of the part number also correspond to the bearing ref No. OEB
iainw
Post by iainw on Sept 19, 2012 19:45:27 GMT 1
i am a little confused i need front wheel bearings for my 31K but my problrm is on his norbships web page there are 3 different bearings being 6301, 6302 and 6202 which ones do i need? Ask Norbo. ;D
Post by Norbo on Sept 20, 2012 9:11:31 GMT 1
All front wheel bearings ar ethe same LC and YPVS and 125 for that matter . its the rears that get are all diferent .
so fronts are fronts simple as that
