Post by pouchy750 on Sept 17, 2012 14:49:38 GMT 1
Is it possible to replace the gearbox (behind the sprocket) oil seal without splitting the cases?
If so, how is it done.
Thanks
Post by marsbar350 on Sept 17, 2012 14:59:17 GMT 1
yes it is take the sprocket off and tease the old seal out tap new seal back in.touch of grease helps welcome to the forum
Post by billyboy on Sept 19, 2012 20:00:01 GMT 1
more than likely the shaft has a groove worn in it and sadly no new seal will make any difference. worth doing both at the same time
Post by rich on Sept 19, 2012 21:04:42 GMT 1
Turn the sprocket spacer round so the seal is running on an unworn part Might need to clean it up first though as they do get surface rust on them.
Post by billyboy on Sept 19, 2012 21:13:52 GMT 1
good thinking batman
