Post by marsbar350 on Sept 5, 2012 15:15:51 GMT 1
this maybe stupid thing to ask.but can you refill the forks with oil through the drain holes at the bottom
Post by Shytalk on Sept 5, 2012 15:48:14 GMT 1
Don't see why not, but why you need to take the cap off to let the oil run out. I would have thought it would be a messy alternative and no guarantee of getting the correct amount into each leg.
Post by marsbar350 on Sept 5, 2012 18:45:31 GMT 1
wont the oil run out of the bottom of the leg? run the oil out.turn upside down refill using a syringe these are a spare set and thought it might be a easier way of doing it ;D
Post by steve h on Sept 5, 2012 19:21:23 GMT 1
If you take them down under you could do it. But if you take the top bolt and plug out you'll lose all the oil, I think? Well something like that anyway.
Post by hooligan on Nov 21, 2012 17:26:06 GMT 1
The top cap is easy enough to remove and you will need to measure the oil height anyway. Filling it upside down through a tin hole seems like a solution to a problem that doesn't exist.
Post by flames on Nov 21, 2012 21:40:36 GMT 1
As above.even filling with syringe i would want to measure the levels afterwards.i would pull cap and fill from top meself.
