jackup
Of all the things I've lost I miss my mind the most
Post by jackup on Sept 4, 2012 16:01:51 GMT 1
The carb on my import mk1 when left empties out of the float over flow the float height appeared to be correct not sure what else it could be any ideas on a fix?
Post by Nismosis on Sept 4, 2012 16:48:16 GMT 1
Is the float needle seating ok? Could be worn? Maybe if it has a full tank of fuel the extra pressure in the fuel line might just cause the fuel to leak past the float needle valve (not sure if this is it's correct name)
Post by mellow on Sept 4, 2012 23:54:39 GMT 1
have u drained it lately if so give the carb a tap and see if it seats the float needle valve thingy
Post by Nismosis on Sept 5, 2012 10:32:16 GMT 1
That's the term.... A float needle valve thingy :-) :-)
Post by liffy16 on Sept 10, 2012 17:08:02 GMT 1
yea that will be the float needle valve, replace with new one job sorted
jackup
Post by jackup on Sept 10, 2012 19:00:14 GMT 1
Swoped it for another seat and valve out of a old 12a carb sorted now
