Post by raven13 on Sept 3, 2012 13:14:35 GMT 1
this bike is now doing my head in. changed stator and cdi and took it out for a ride and still no revs above 5k. but it revs freely wen not under any load wats next??
Post by Norbo on Sept 3, 2012 13:44:21 GMT 1
Have you had the top end of are the rings stuck in. Have you got the washer under the main jet .
Post by raven13 on Sept 3, 2012 14:21:08 GMT 1
it was running fine before the stator went belly up. will pull the carb and check for a washer
Post by Norbo on Sept 3, 2012 14:25:30 GMT 1
so did you replace it or have it rewound
Post by raven13 on Sept 3, 2012 14:29:11 GMT 1
ive rried the one i had rewound be west coast and one i bought from a forum member. both the same.
Post by mudguts on Sept 4, 2012 18:01:50 GMT 1
I bought a Rd125lc Mk3 which would not rev over 5k, turned out it had a mk1 conrod in it, 5mm too short!
Post by mudguts on Sept 4, 2012 18:02:53 GMT 1
have you checked the pickup coil clearance and ohms,
Post by raven13 on Sept 4, 2012 20:16:00 GMT 1
Post by jaylee22 on Sept 6, 2012 10:02:53 GMT 1
sorry to hear it's not fixed raven. it sounds daft but i've had this once before and it turned out to be the spark plug!! worth a try?
Post by Norbo on Sept 6, 2012 10:51:04 GMT 1
loos conection on the Ht coil worth a look .
Post by raven13 on Sept 14, 2012 13:58:22 GMT 1
update time. changed the plug,stator,coil,checked all the wiring. and still no difference. then changed the 10w carb that was on it for the 12A i had as a spare and hey presto goes like stink. anyone got any ideas as to why this could be? click the picture to hear her crackle
Post by Nismosis on Sept 14, 2012 14:52:04 GMT 1
Maybe the throttle slide was not opening fully? Blocked main jet? Problem with the choke cicuit or even the choke 'flap' not fully opening when the choke is off?
I'm glad it's sorted and running as it should. If only there was an RD bible with all the answers :-)
Post by raven13 on Sept 14, 2012 16:07:31 GMT 1
there is an RD bible. its this place.
Post by Nismosis on Sept 14, 2012 16:18:24 GMT 1
Post by porkyhorse on Nov 2, 2012 21:25:43 GMT 1
Hi I've got the same problem but it doesn't like starting either
