Post by mudguts on Aug 14, 2012 20:02:48 GMT 1
Hi, Could someone tell me what the pickup coil/flywheel gap should be on a Mk3 rd125lc and a tzr125 please
thanks mudguts
Post by proam350 on Aug 15, 2012 20:34:29 GMT 1
factory set mate cant be set plain holes not slotted fot addjustment if you flywheel hitting the pick up coil your left hand crank web must be bent or you flywheel loose or maybe the woodruff key moved when flywheel was fitted and then flywheel not on taper inline
