Post by pricey797 on Jul 14, 2012 18:59:31 GMT 1
well people , went for a little ride out this afternoon , nice nearly home and bang one hell of a scrapping noise from transmission side of engine so looks looks a re build sooner than i was planning gutted to say the least
Post by pricey797 on Jul 14, 2012 19:00:12 GMT 1
any ideas what it could have been still starts and rides only a scrapping noise
Post by LC_BOTT on Jul 16, 2012 11:55:41 GMT 1
sprocket coming off? or other side of engine, clutch nut loose, water pump bearing, clutch plates broken, crank f~~~d, crankcases broken in half, hard to tell really, sounds like you haven't even had a look round it to me, dangerous to go riding out on it?
Post by pricey797 on Jul 16, 2012 12:05:02 GMT 1
it was fine before hand , engine out stripped , looks like the gear shaft thats higher up in box has got hot shaft is blueing all bearings run fine and quiet so looks like i need the top shaft and gears /selectors have worn too, crank is fine cant understand why its got hot there was oil in there
Post by pricey797 on Jul 16, 2012 12:12:40 GMT 1
can anyone shed a light onto whether a 1985 gearbox parts will fit the 1984
Post by mellow on Jul 16, 2012 19:35:51 GMT 1
pretty sure the bottom ends are all the same.
Post by Norbo on Jul 17, 2012 8:34:23 GMT 1
Befor you get to worred have you looked at the fly wheel to see if its come loos . some times that can make a hell of a racket and people think the engin has fallen apart and the like and its just the flywheel come loos and clattering about in the cover. more so on an lc as the cover is alloy but its worth alook .
Post by mellow on Jul 17, 2012 16:46:47 GMT 1
im sure i already said that ;D
Post by pricey797 on Jul 17, 2012 19:54:52 GMT 1
no the flywheel was tight its definately gearbox bits , acquired a new set today well new as in new to me and in great condition so just need a gasket set and rebuild the engine back together ,fingers crossed should be all good,
