top end
Jul 11, 2012 10:22:12 GMT 1
Post by pricey797 on Jul 11, 2012 10:22:12 GMT 1
hi all cant seem to keep any speed up in 5th and 6th gears , bike goes well through the first 4 when changing up seems to bog down after going into 5th any ideas
jackup
Of all the things I've lost I miss my mind the most
top end
Jul 11, 2012 21:15:04 GMT 1
Post by jackup on Jul 11, 2012 21:15:04 GMT 1
What's your jetting on your carb also does your barrel say 10v?
top end
Jul 12, 2012 15:24:05 GMT 1
Post by pricey797 on Jul 12, 2012 15:24:05 GMT 1
hi jets are a 195 which sugests a 12a carb and my barrel says 10w but head says 10v
cj
top end
Jul 12, 2012 17:30:00 GMT 1
Post by cj on Jul 12, 2012 17:30:00 GMT 1
Sounds daft but worth checking sprocket ratios
top end
Jul 12, 2012 18:05:41 GMT 1
Post by pricey797 on Jul 12, 2012 18:05:41 GMT 1
sprockets are 16 front and 46 rear would it be that its a deristricted engine and a restricted carb seems its all a 10w head and so on with a 12a carb
jackup
top end
Jul 12, 2012 18:32:37 GMT 1
Post by jackup on Jul 12, 2012 18:32:37 GMT 1
Spokets are fine heads fine carb is jetted standard so unless you have got a micron on its could be something blocking your carb give it a good clean and blows out
top end
Jul 12, 2012 18:43:41 GMT 1
Post by pricey797 on Jul 12, 2012 18:43:41 GMT 1
carb been cleaned , correct me if i am wrong but a standard 12a restricted carb is fitted with a 195 main jet and a 2.5 air jet , 0-2 needle and the 10w de ristricted carb is fitted with a 155 main jet a 1.0 air jet and a 0-8 needle , so if i have a 10w head, exhaust with hitec reeds should i no tbe using a 10w carb , i understand that the carb i have is jetted standard bu twith everything else 10w would it be beneficial to get a 10w carb
top end
Jul 12, 2012 22:19:49 GMT 1
Post by mellow on Jul 12, 2012 22:19:49 GMT 1
Heads have 10V on im sure i doubt its ur carb as they work on throttle position as such.Read the Mikuni carb tuning bit in TECH SECTION. I dont think any rev out in 6th. mine will do 80 all day everywhere in 4th but show it 5th gear n u have to have the revs right up in 4th to keep it in the band Id say go down one on front sprocket or up 2 on the rear and good luck finding a 10W carb ;D
jackup
Post by jackup on Jul 13, 2012 0:05:07 GMT 1
I agree with mellow fitting a 10w carb won't make a difference go back to basis do a plug chop check your kneedle valve ,make sure your choke circuit is clear also fit a standard reed block and check the rubber around the reed block for a good seal .if you need a standard reed block I am sure I've got one you can have foc
top end
Jul 13, 2012 17:10:07 GMT 1
Post by pricey797 on Jul 13, 2012 17:10:07 GMT 1
can i ask why a 10w carb wont help , not being funny or anything and i certainly dont know it all but why would there be a restricted carb 12a and a full powercarb 10w if it wont make a difference, or am i missing something simple here
jackup
top end
Jul 13, 2012 17:15:48 GMT 1
Post by jackup on Jul 13, 2012 17:15:48 GMT 1
It's might make a difference but only if the carb you got was clean should get the same results with a clean 12a and a unrestricted exhaust
top end
Jul 13, 2012 18:47:49 GMT 1
Post by pricey797 on Jul 13, 2012 18:47:49 GMT 1
will a standard airbox help any , got the connection part just need the top chamber , also its lumpy if you hold throttle on around 1/4 to 1/2 at low speeds , ie doing 30 at a steday throttle input its lumpy soon as i open throttle its great
top end
Jul 13, 2012 18:48:46 GMT 1
Post by pricey797 on Jul 13, 2012 18:48:46 GMT 1
anyone localish to anglesey that could listen / road test it fo rme its my first one so no tsure how it should be anyway am i expecting too much
jackup
top end
Jul 13, 2012 18:57:17 GMT 1
Post by jackup on Jul 13, 2012 18:57:17 GMT 1
That's your problem you need a standard air box in the meantime try upjeting to compensate for the increased air flow I've just sold my spare air box to snowbound so good luck getting one
top end
Jul 14, 2012 10:22:50 GMT 1
Post by pricey797 on Jul 14, 2012 10:22:50 GMT 1
sure norbo has the parts i need for sale on here so payday big order from me , got the part that links the airbox to the carb in its way fron the well known auction site and just got a 10w carb from the same site also on its way so hopefully it should improve in next couple of days
top end
Jul 14, 2012 17:02:21 GMT 1
Post by billy on Jul 14, 2012 17:02:21 GMT 1
What does it say on the exhust? We had a Y11 (or something like that, I can't remember the exact serial numbers/letters atm) exhaust on dads 125, and it was restricted like mad. We then put on a 10w exhaust and hey ho, it went fine.
