Post by photoman1963 on Jul 9, 2012 21:47:19 GMT 1
Ive just changed handlebars and the throttle is quite stiff and Does not return back Fluidly any advice how to freed it up!?
Post by marsbar350 on Jul 9, 2012 21:52:08 GMT 1
try oiling the cable.make sure the nipple has located properly in the throttle twist grip
Post by 47x on Jul 9, 2012 21:56:15 GMT 1
make sure the handlebar is spotless where the twistgrip goes,lighly oil it as well...p.s.dont u read your messages? .sent you 2
Post by peterlc2 on Jul 9, 2012 22:10:37 GMT 1
Bar end too tight
iainw
Post by iainw on Jul 9, 2012 22:21:27 GMT 1
Is it painted black? Take it down to the bare metal.
Post by ducatidave on Jul 9, 2012 23:01:17 GMT 1
Is it painted black? Take it down to the bare metal. Yes that will b it happend 2 me : )
Post by ducatidave on Jul 9, 2012 23:02:29 GMT 1
Use sharp blade u b ther allday with sandpaper
Post by Norbo on Jul 10, 2012 6:27:18 GMT 1
All new bars are powdercoated and right to the end so most need the paint removing at the throttle end so the twist grip moves freeley
Post by robsypvs on Jul 10, 2012 16:26:35 GMT 1
Never had to do that with my Renthalls as they are anodised!
phil38
Post by phil38 on Jul 10, 2012 19:16:28 GMT 1
Check the bar grip is not rubbing on he bar end. I did all the other things first then realised this was the cause on mine!
iainw
Post by iainw on Jul 10, 2012 20:02:56 GMT 1
Use sharp blade u b ther allday with sandpaper Tear a long strip and wrap it round, pull up and down very quickly. It only takes a few minutes. ;D
