Post by photoman1963 on Jul 9, 2012 17:02:24 GMT 1
Can you guys assist I need replacement satin black cast bracket that holds the mirror/brake fluid assembly to handlebar, mine has cracked between the two bolts can anyone recommend repair or where to get replacement? Do I have to buy whole assembly unit or liquid metal/ araldite it?
Post by arrow on Jul 9, 2012 19:03:22 GMT 1
Someone should have one. I wouldn't think about trying to fix it with epoxy etc, It will fail and then you got no front brake. A fatal error.
phil38
Post by phil38 on Jul 10, 2012 19:20:29 GMT 1
Someone should have one. I wouldn't think about trying to fix it with epoxy etc, It will fail and then you got no front brake. A fatal error. +1
