Post by curz on Jul 3, 2012 16:27:47 GMT 1
Post by Trubrit on Jul 3, 2012 17:10:15 GMT 1
Hook It Up To A Master Cylinder , Works Every Time For Me.......
Post by crash on Jul 3, 2012 17:22:27 GMT 1
or stick a airline into it,watch them fingers if the piston flings out .
tzer
Post by tzer on Jul 3, 2012 18:26:55 GMT 1
nothing beats a good quality grease gun attached to the bleed nipple, block the union hole up with one of the caliper mounting bolts...pump grease in first just to blead the air out tighten bolt and continue to pump the grease pressure! CAUTION the piston can come out like a bullet! pack with rags to stop injury .
Post by curz on Jul 3, 2012 19:39:23 GMT 1
;D i'm gonna try all 3 methods, i'l let you know how it goes huys ;D
Post by proam350 on Jul 3, 2012 19:54:03 GMT 1
the piston looks like its jammed on an angle looking at the pic i would push it back in with a g clamp then air gun to push it back out...good luck
Post by gerumgoin on Jul 3, 2012 20:40:09 GMT 1
the piston looks like its jammed on an angle looking at the pic i would push it back in with a g clamp then air gun to push it back out...good luck same here,get it back level first ;D
Post by LC_BOTT on Jul 3, 2012 21:24:38 GMT 1
I'm with tzer on this one, use a grease gun (I tapped a 5mm grease nipple into an old banjo bolt) It's much more controllable than using an airline, never had one 'blow' out so far, used the other methods too, but I sometimes take them to work and do them. Soaking it in oil possibly hasn't helped, as it will swell the seals.
Post by gerumgoin on Jul 4, 2012 5:32:16 GMT 1
Didnt someone say in another thread about using heat and ice cubes ?? not sure
Post by ngordoncrosby on Jul 4, 2012 8:38:50 GMT 1
Put a flat plate on the front of a G clamp and then just wind it up, it will move
Post by curz on Jul 4, 2012 9:50:49 GMT 1
back on it today! ;D right, piston back in level, (g-clamp and flat plate did it nicely) its been soaking in white vinegar overnight again! ive 'sourced' a master cylinder to try that method, (mine is stripped), then im usin the greasegun method, im tryin every method put on ere 1 at a time until it shifts!! ;D
Post by pricey797 on Jul 4, 2012 12:31:02 GMT 1
+1 on the airline worked for me
Post by 47x on Jul 4, 2012 12:44:24 GMT 1
didnt the "ice cube" method work the other day on one????think it was raven or jackup who mentioned it
Post by bigal1 on Jul 4, 2012 12:59:25 GMT 1
get a new piston and drill a hole in the side of the old 1 and lever it out with a good screw driver
Post by curz on Jul 4, 2012 18:02:43 GMT 1
;D i thought you guys would like this, im still at it but its a little shit,
Post by raven13 on Jul 4, 2012 20:52:34 GMT 1
ive used the ice cube method a few times now and as long as your willing to replace the seals and possibly the piston it normally works a treat. i heat mine over the cooker ring tho as they get a lot hotter than the over.
Post by Deleted on Jul 4, 2012 21:23:29 GMT 1
had the same problem, the air line worked for me, (well i say me lol nice if you mates the manager of your local kwikfit, took it into work and got one of his minions to blast it out). once out i cleaned it up repainted new piston and seal nd its great.
Post by bigal1 on Jul 5, 2012 10:48:24 GMT 1
can i have chips with that lol
jackup
Of all the things I've lost I miss my mind the most
Post by jackup on Jul 7, 2012 15:43:46 GMT 1
And onion rings to please
Post by curz on Jul 18, 2012 19:28:19 GMT 1
;D been plodding on... waiting for new piston an seal kit to arrive now an its done im getin there ;D
Post by LC_BOTT on Jul 18, 2012 20:34:30 GMT 1
Well tell us how you got it out then??
Post by broughton5 on Jul 18, 2012 20:44:51 GMT 1
bet you just spoke to it really nice didnt you
Post by curz on Jul 18, 2012 20:58:10 GMT 1
oh yeah, i forgot to put that, Greasegun method did it nicely, just blocked the brakeline hole an attached a greasegun to the bleed nipple, it seemed the safest an least mess to try first an it worked nicely, i was weary of tryin an airline again an didnt want to get brake fluid everywhere, the insides are in good nick, there has been brake fluid in it as it has be stored so im replacing the piston, seals, fitted stainless bleed nipple and banjo bolts an given it a coat or 5 of matt black vht paint
Post by mellow on Jul 18, 2012 23:22:26 GMT 1
hope u copper greased the nipple thread
Post by curz on Jul 19, 2012 3:25:43 GMT 1
;D of course mellow, ya always gotta keep ya nipples greasy!!
Post by Norbo on Jul 19, 2012 7:27:44 GMT 1
Well it looks like new now . looks like all the efort has payed of .
Post by curz on Jul 19, 2012 8:24:02 GMT 1
Cheers Norbo ;D Things are fallin into place an im gettin the right advice when its needed ;D useful bunch of lads on ere ;D ;D
Eyeore
Post by Eyeore on Jul 19, 2012 12:01:40 GMT 1
Personally I like originality, it looked fine as it was.
Post by curz on Jul 19, 2012 19:15:52 GMT 1
Personally I like originality, it looked fine as it was. ;D ;D ;D ;D the worn in look ;D ;D ;D
Post by Norbo on Jul 20, 2012 11:34:11 GMT 1
Personally I like originality, it looked fine as it was. ;D ;D ;D ;D the worn in look ;D ;D ;D Just like me then well worn , Or should that be worn out
