tzer
Post by tzer on Jul 3, 2012 11:17:49 GMT 1
Hi Iam having problems setting the ypvs valve up. I can get the valve lined up correctly looking up the exhaust port, but the index mark (4mm drill bit hole) is slightly out of line (backwards) and the fr cable adjuster is sitting on the housing rather than screwed into it?? anyone know if Ive screwed up something? are both the ypvs cables the same? thank you all
Post by 47x on Jul 3, 2012 11:22:37 GMT 1
the cable should be screwed into housing.then you adjust the cables to pull valve into alignment.im sure cables are same length.
tzer
Post by tzer on Jul 3, 2012 18:33:42 GMT 1
yes cables should be screwed into housing but mine will not line the valve up unless cable no1 is hanging out of the threads?? all the cables for this bike all seem not quite right... thanks for your input 47x..oh that was your 666th post
Post by 47x on Jul 3, 2012 19:58:22 GMT 1
lol,cheers for noticing that!!!is the servo in the at rest position??turn on ignition,let it come to normal position,try again,threads must be screwed into housing.
paulo
Post by paulo on Jul 4, 2012 22:02:15 GMT 1
As 47x has said, turn on ignition ypvs pulley should rotate anticlockwise - open position. Turn off ignition before the servo cycles back to the closed position. Adjust cables to align pulley cut-out with 4mm hole in housing and that should be job done.
Post by mellow on Jul 4, 2012 23:17:07 GMT 1
mine are genuine cables.i think one is slightly longer.also one of mine is almost out of the housing.but it works fine
Post by rich on Jul 4, 2012 23:30:39 GMT 1
Alos make sure you have the cables the right way round as they are numbered 1 and 2 on the servo and pulley housing. I would ignore the alignment hole, just poke your finger up the exhaust port and make sure the valve is flush with the port roof at the servo rest position. Far more accurate way of doing it.
tzer
Post by tzer on Jul 6, 2012 23:43:19 GMT 1
oh..might be to do with the fact Ive been doing it with the ignition turned off! I was using the finger up the port method, but definatly noted the index mark (4mm hole) was not perfectly alined with the other hole?? strange but true tar all for help... the more I solve the more pops up, its snaped its frame now!!
