Post by captaincaveman on Jul 1, 2012 17:26:36 GMT 1
Well the lc is almost finished so today i was already to start it. Pulled my tank down from the attic where is been for the last few weeks wrapped in bubble rap. Unwrapped it to find my paint work to put is short is f**ked. Looks like some how the bubble wrap has gone into the paint and left snow like marks all over it. Ive not yet opened the other panels but im expecting it all to be the same So there i was with the tank in my hands almost about to drop kick it down the drive. Think it was only the thought of how much ive spent on it kept it in my hands. So i thought f**k it let at least try and start it petrol in the tank new plugs new loom bit of petrol down the bores plugs in and kick it. Well it gets worse Its only firing on the right hand side and the exhaust is blowing from the front. taken the plug out of the right hand side, its wet so its getting petrol and there's a spark. At this point in time its coming very close to either being stuck on ebay or parked next to my other dead bike with a cover over it and left.
Post by peterlc2 on Jul 1, 2012 19:13:38 GMT 1
Take some time out give it a day and go back I'm sure you will get it sorted
Post by arrow on Jul 1, 2012 19:17:58 GMT 1
I warned people a while ago about wrapping paint work in bubble wrap, sorry mate.
Post by 47x on Jul 1, 2012 19:21:35 GMT 1
also dont asume new plug is good!
Post by arrow on Jul 1, 2012 19:23:00 GMT 1
also dont asume new plug is good! Correct. And why you putting petrol down the bores ? Its probably got too wet.
Post by 47x on Jul 1, 2012 19:42:06 GMT 1
also dont asume new plug is good! Correct. And why you putting petrol down the bores ? Its probably got too wet. yep,especially if your using choke
Post by captaincaveman on Jul 1, 2012 19:46:06 GMT 1
Manged to sand out most of the bubble wrap marks out of the tank don't know if the rest of the panels will be ok i put less lacquer on them.
Always have put a drop of petrol down the plug hole when starting from fresh gives it bit of a head start.
Ive swapped the carbs over just to see if it would fire and it did so it seems the problem is with the left hand carb.
Wish i,d seen what you had posted about the bubble wrap through.
Post by 47x on Jul 1, 2012 19:51:44 GMT 1
might be a bit of crud from the bottom of tank or fuel tap blocked the carb,nothing a clean wont sort!
Post by captaincaveman on Jul 1, 2012 20:55:52 GMT 1
Checked that both flowing freely
Post by steve h on Jul 1, 2012 21:05:58 GMT 1
Take some time out & have a smoke. Cat fags, 14mg bloodcurdling screams @ 2am, 3mg old boot throwing, 200mg cat turds on your freshly planted flower bed.
Post by Delbert on Jul 1, 2012 21:45:14 GMT 1
balance pipe thats a common one to forget
Post by captaincaveman on Jul 1, 2012 22:05:46 GMT 1
No thats on as well.
Post by arrow on Jul 1, 2012 22:14:59 GMT 1
Do you have the pilot jets in both carbs ? Its been done before, no pilot jets, engine runs like a pig if you can start it.
Post by captaincaveman on Jul 2, 2012 17:22:58 GMT 1
There both in place, ive tried the left hand carb on the right hand cylinder it did fire not long mind as i only had the one carb fitted. But at least now i do know its a carb problem rather than the cylinder. I have noticed this hole is blocked as in i cant blow through it but i can blow through it on the other carb.
Post by arrow on Jul 2, 2012 17:40:09 GMT 1
That hole is not supposed to be drilled through. Only the outside of the R/H carb and the inside of the L/H carb have pipes on and are drilled through.
Post by captaincaveman on Jul 2, 2012 18:07:32 GMT 1
ok thanks that one less thing to think about.
