Post by hardhatharry on Jun 29, 2012 15:15:55 GMT 1
My crank and barrels have gone off to get rebuilt, rebored and new pistons.
While the engine is in 100 bits what else should I be replacing as a matter of course
Post by arrow on Jun 29, 2012 15:32:39 GMT 1
All the bearings, seals, circlips and 'O' rings.
Post by midlifecrisisrd on Jun 29, 2012 15:54:05 GMT 1
All the bearings, seals, circlips and 'O' rings. I'd add pv bushes and seals, would rather have extra expense and know it was 100% and won't have to take to bits again for a long while. Steve
Post by hardhatharry on Jun 29, 2012 16:13:55 GMT 1
Dont suppose anyone (Norbo?) does a kit with all the required seals etc you can buy in one kit.
I already have a full gasket set
Post by LC_BOTT on Jun 29, 2012 16:31:42 GMT 1
Don't forget the water pump seal, started mine up after a full rebuld, and had milky oil within the first 50 miles. Oldparts shop does the full kit sometimes on fleabay, about £40 ish and all genuine? apparently.
Post by midlifecrisisrd on Jun 29, 2012 18:41:26 GMT 1
Dont suppose anyone (Norbo?) does a kit with all the required seals etc you can buy in one kit. I already have a full gasket set Norbo will sort you out with all the rubbery bits Steve
Post by woodentopp on Jul 4, 2012 17:05:43 GMT 1
Yambits does a seal kit, oli pump kit and water pump kit as well as a full gasket set. There is a bit of overlap between the kits however.
