Post by captaincaveman on Jun 28, 2012 19:31:09 GMT 1
ive got a bottle of pre mix 2 stroke oil in the shed. Would it be ok to put in the rd. I mean in the oil bottle and not mix it. I heard/red while ago that pre mix oil is thinker so it may not run through the pipes the same?
Post by arrow on Jun 28, 2012 19:33:40 GMT 1
Any specs. on the bottle ?
Post by captaincaveman on Jun 28, 2012 20:23:27 GMT 1
What you mean specs?
Post by rdstars on Jun 28, 2012 20:27:25 GMT 1
If it's a spare bottle there I would just use it to lube parts as you put it all together, don't want to feed it any old rubbish or mess around with a motor build as nice as your doing.
Post by captaincaveman on Jun 28, 2012 20:59:31 GMT 1
Its only a month or 2 old bought it for a trials bike i had Its Putoline and it smells of strawberry's ;D
Just it would have been handy when i try to bleed the pump at the weekend but i see what you mean pointless scrimping now so i,l pop into tesco on the way home tomorrow ;D
Post by arrow on Jun 29, 2012 6:41:17 GMT 1
Specifications.
Post by chamber66 on Jun 29, 2012 7:39:01 GMT 1
Its only a month or 2 old bought it for a trials bike i had Its Putoline and it smells of strawberry's ;D Just it would have been handy when i try to bleed the pump at the weekend but i see what you mean pointless scrimping now so i,l pop into tesco on the way home tomorrow ;D You're to tight for Tescos. Didn't you run a bike on old diesel once lol ;D
Post by captaincaveman on Jun 29, 2012 21:20:17 GMT 1
They things you do when your a skint school kid living on a housing estate ;D You wouldn't understand that Old ts 250 50/50 cherryade nicked from a local coal mine and petrol sounded odd smoked like a steam train but run ;D ever tried to grind new teeth into a tooth less sprocket ;D Them were the days
Post by lovelydog on Jun 29, 2012 22:05:40 GMT 1
They things you do when your a skint school kid living on a housing estate ;D You wouldn't understand that Old ts 250 50/50 cherryade nicked from a local coal mine and petrol sounded odd smoked like a steam train but run ;D ever tried to grind new teeth into a tooth less sprocket ;D Them were the days Awwww,mate, I've done a chain up as tight as a bar when there's been no teeth on the front sprocket,used a mole-grips as a gear selector clamped around the splines and even had to ride one handed while I pull the throttle cable direct from the carb with my right hand. Ahhh, the folly of youth.
Post by chamber66 on Jun 29, 2012 23:12:16 GMT 1
Post by steve h on Jun 30, 2012 0:01:55 GMT 1
90psi in the back tyre so its stays up long enough to get to work, untill you can afford a new inner tube.
Post by 47x on Jun 30, 2012 0:05:38 GMT 1
ho-hee-hee....we all been there buddy...lol!
Post by arrow on Jun 30, 2012 0:35:41 GMT 1
I always maintained my bikes well, right back to the 80's. Sorry to be boring. Then, as is now, if it wasn't right, I would put it right.
Post by captaincaveman on Jun 30, 2012 8:29:59 GMT 1
The mole grips on the gear stick was a classic. Before you could get some nice chappy to weld the gear stick back on. ;D
You see the fun you missed out on chamber with your posh private education.
Post by 47x on Jun 30, 2012 8:35:56 GMT 1
LOL!!!
Post by chamber66 on Jun 30, 2012 8:40:17 GMT 1
The mole grips on the gear stick was a classic. Before you could get some nice chappy to weld the gear stick back on. ;D You see the fun you missed out on chamber with your posh private education. First time I have ever hears Maesydderwen comprehensive called posh ;D So can't you fix your WR with duct tape then?
Post by captaincaveman on Jun 30, 2012 10:43:31 GMT 1
Dim
Post by chamber66 on Jun 30, 2012 12:08:12 GMT 1
Dim Do you want me to do it for you?
Post by captaincaveman on Jun 30, 2012 21:34:05 GMT 1
Double dim but you could ask you nice dad to once he,s finished doing the rd for you ;D
Post by 47x on Jun 30, 2012 21:35:29 GMT 1
john,did you get brakeline m8??
Post by chamber66 on Jun 30, 2012 22:09:16 GMT 1
john,did you get brakeline m8?? yep thanx Steve I hate you
