Post by hardhatharry on Jun 27, 2012 19:48:30 GMT 1
Managed to snap one of the long engine bolt near the base which connect the base of the barrel to the top case on an RD 350 YPVS 31K engine I know this is a strengthened bolt, any super tips how to get this out?
Post by crash on Jun 27, 2012 19:52:03 GMT 1
any pics?
Post by hardhatharry on Jun 27, 2012 19:55:39 GMT 1
Just added one
Post by rigga on Jun 27, 2012 19:57:45 GMT 1
center punch, small pilot hole and a eeze out ??
Post by hardhatharry on Jun 27, 2012 20:00:12 GMT 1
ah centre punch yes, been meaning to buy one of those, nows the time
Post by rdstars on Jun 27, 2012 20:21:12 GMT 1
I hate doing thread repairs but if you do go the easy out route then warm up the case around the bolt first.
Still if your not good or experienced with thread repair etc then take it to your local engineers, should not cost more than about £20'ish and you wont have the hassle of doing it yourself.
Post by crash on Jun 27, 2012 20:22:56 GMT 1
i agree with rdstars,very easy to balls this up and make it worse
Post by nikfubar on Jun 27, 2012 20:26:02 GMT 1
If it doesn't come out relatively easy with an easy out then drill it out & re-tap. If you snap an easy out off in the whole then your in a world of problems cos you can't drill em
Post by rdstars on Jun 27, 2012 20:30:10 GMT 1
Talking of thread repairs and hate doing them I had an M8 Stainless snapped in something today and had to repair that, not good, hate repairing threads and that is being able to do them so for someone new then get someone else to do it.
Post by hardhatharry on Jun 27, 2012 20:50:41 GMT 1
Are the engine bolts still available from Yam? Or somewhere else?
Post by jessy03 on Jun 27, 2012 22:05:03 GMT 1
Think I have a new one in the garage you can have, send me your details. Jess
Post by hardhatharry on Jun 27, 2012 22:12:27 GMT 1
Cool Jess,
Will PM details, let me know how much I owe
Post by bluebellc on Jun 27, 2012 23:15:15 GMT 1
How did you manage to snap it? John.
Post by steve h on Jun 27, 2012 23:22:27 GMT 1
Eating to much spinach? ??
Post by LC_BOTT on Jun 28, 2012 0:01:08 GMT 1
There's possibly not enough stud left, but a good welder should be able to 'stick' a nut on, and just unscrew it with a socket/spanner, the heat helps expand the case too.
Post by midlifecrisisrd on Jun 28, 2012 8:00:02 GMT 1
As nik says I would be wary of using a stud extractor as they are brittle and if you use a large one they have a tendency to splay the top of the stud which can damage the alloy around it.
Also if the stud has sheared it implies it is stuck very tightly so in my opinion spark erosion is the only option for that so best left to a competent engineer.
Post by hardhatharry on Jun 28, 2012 10:00:21 GMT 1
Looking at the snap mark on the bolt it looks as it was cracked previously and I helped the situation by trying to undo the nut
Post by lcrider on Jun 28, 2012 11:09:55 GMT 1
OOO take your time mate this could go all wrong for you . you get some reverse taped bolt removers cant you may be worth looking in to one of them
Post by 47x on Jun 28, 2012 11:28:44 GMT 1
be careful m8,it is easy to c**k these things up...but if your SURE it was cracked before,you should have no probs with stud extractor.good luck!
phil38
Post by phil38 on Jun 28, 2012 12:27:42 GMT 1
I'd take it & get it drilled out in a machine shop. If it snapped off with a socket then an easy out will not do it. Once you've snapped the very hard & brittle easy-out in the middle of the stud it's much harder to drill it out. I've just done the same with a head stud!
Post by Deleted on Jun 28, 2012 12:49:11 GMT 1
i tried to do something similar to this, buggered it up and swore id pay some to do it in the future if it happened again,,
Post by bigal1 on Jun 28, 2012 13:25:02 GMT 1
if i was u i would replace all these and if your not 100% sure you can do this get someone to do it if you dont drill this out straight you will fek it up ...
Post by hardhatharry on Jun 28, 2012 13:51:04 GMT 1
Well plan A is to get the top case off see how much is visible and try an automatic centre punch to see if I can shock some movement into it. If it wont budge its off to the pro's
Post by bigal1 on Jun 28, 2012 16:40:52 GMT 1
all the best with it let us know o you get on
Post by jessy03 on Jun 28, 2012 19:34:55 GMT 1
Yes I have one new in bag, well two different ones, which one is it you require - 90116-08368 or 90116-08064. Let me know and I'll put it in the post. Jessy
Post by Shytalk on Jun 28, 2012 20:57:37 GMT 1
90116-08064
Post by jessy03 on Jun 28, 2012 21:09:57 GMT 1
Nice one, I'll put it the post for ya hardhatharry. Jess
