jetting
Jun 26, 2012 21:33:05 GMT 1
Post by pricey797 on Jun 26, 2012 21:33:05 GMT 1
hi all right want to start from scratch so to speak , need to re jet my carb as i am not sure what it should be, its a 10w for with a deristricted standard exhaust and a k&n filter , i am unsure if its set right as it will start from cold no choke, so asking you kind folk where should i start with jetting cheers all
jackup
Of all the things I've lost I miss my mind the most
jetting
Jun 26, 2012 21:52:20 GMT 1
Post by jackup on Jun 26, 2012 21:52:20 GMT 1
The standard jet is 155 for a 10w carb I would whip out your main jet and see what you have now also check your kneedle position ,if it starts from cod without choke it's proberley been up jetted a bit too high Also fit a standard air box k&n are crap on a lc
jetting
Jun 26, 2012 22:17:30 GMT 1
Post by pricey797 on Jun 26, 2012 22:17:30 GMT 1
i will get an airbox when i see one lol for the right money just need it running as best i can as is at moment for what may be left of summer , then in winter will strip and rebuild it
jetting
Jun 27, 2012 16:58:42 GMT 1
Post by mellow on Jun 27, 2012 16:58:42 GMT 1
my mk3 starts with no choke if that helps
jetting
Jun 30, 2012 21:45:52 GMT 1
Post by proam350 on Jun 30, 2012 21:45:52 GMT 1
do a plug chop see wot colour the plug is mate
