Post by mudguts on Jun 24, 2012 10:31:38 GMT 1
Hi Forum Im not new to lcs but powervalves are new to me, Ive a Mk 3 without servo, could anyone tell me how to fix the valve to the fully open position,
thanks mudguts
Post by Norbo on Jun 26, 2012 6:31:30 GMT 1
If you remove the end cap and the exhorst you can turn the valve with a set of plyers untill its flush with the top of the cylinder then its fully open . No bottem end at all mined you its like riding a push bike . but when the band come in it will be flying .
Post by 47x on Jul 16, 2012 14:41:06 GMT 1
or,you can set up a manual 1 !get a pulley and fit it to the end of the valve/housing,get a choke cable and lever,put it on your handlebar,close it for around town(better low down power)open it for balls out riding(valve fully open)its easy to do,and a lot cheaper than getting a servo/loom etc.. .although i would get a servo and that(or a 350!!! ;D)
