Post by gerumgoin on Jun 17, 2012 12:26:19 GMT 1
Hey all,so the 2hk bike is coming together,a bit of help on the setting up of it. 1st As its the non working power valve,atm its had a re bore to 57.75 and i have left the valve open permanently,would you do this or not? 2nd Its got a Gianelli exhaust fitted so if the valves left open and with this exhaust what jetting would you go for? oh and its got a standard airbox fitted
Post by mellow on Jun 17, 2012 22:46:32 GMT 1
id leave it open or ul lose top end go up 2 on main jet n do plug chops.there's a carb tunin article in tech section
Post by gerumgoin on Jun 18, 2012 5:29:13 GMT 1
cheers mate
Post by proam350 on Jun 20, 2012 20:45:57 GMT 1
i would just open valve 3/4 of the way give it a bit of midrange or will be flat till 7000rpm start with 230 main jet needle 1 notch off the bottom air screw 1 n half turns out from full in. then plug chop
