Post by chamber66 on Jun 17, 2012 9:01:51 GMT 1
I need some clocks for my build. What other clocks will work?
Yamaha FZ maybe , any one know, what options I have?
Post by midlifecrisisrd on Jun 17, 2012 11:34:11 GMT 1
Hi,
It has to be a YPVS tacho as it works of the trigger from CDI to PV controller and not pulse from coil.
Even if you use a 4 stroke tacho and trigger from coil it will read double so no good.
You can use early FZR 400/600/1000 clocks with a YPVS tacho as the cases are similar to N clocks but speedo exits at a different angle. I have done this a couple of times. Only prob is that the speedo is white lettered and the tacho would be red lettered unless you can find an import tacho as it was white and usually had the speed warning light in it. Only issue with that was that the really late model ones used the coil trigger as it had a combined CDI/PV controller (RZ250) but you can always change the trigger if it is different.
Post by chamber66 on Jun 17, 2012 12:04:18 GMT 1
Thanks that was a cracking answer ;D
So anyone have a rev counter or clocks to sell?
Post by rdstars on Jun 17, 2012 12:27:08 GMT 1
Yep, I can help you out there. Can sell you a complete clock set
Post by marddy on Jun 17, 2012 13:24:00 GMT 1
Have another one? Let me know please.
