webbo
Post by webbo on Jun 10, 2012 20:10:58 GMT 1
How many miles and what sort of revs should run at on a rebored and rebuilt crank 4L0 motor. Cheers.
Post by arrow on Jun 10, 2012 21:02:58 GMT 1
Excellent write up on this by Norbo in the tech. section, near bottom of the page.
Post by oldelsieboy on Jun 10, 2012 21:06:09 GMT 1
How many miles and what sort of revs should run at on a rebored and rebuilt crank 4L0 motor. Cheers. Make sure it properly warmed up, then ride it like you stole it ;D OEB
Post by tobster on Jun 10, 2012 21:47:07 GMT 1
+1 for oldelsieboy's approach.
webbo
Post by webbo on Jun 10, 2012 23:02:34 GMT 1
Just read Norbos bit, thanks Arrow! Only 150 miles to go ;D
Post by bare on Jun 11, 2012 17:23:02 GMT 1
Heat cycle it at least 6 times Run it 'til it's warm .. let it cool down to ambient temp.. then repeat. Before riding it Pistons need heat cycling to relieve mfg stresses . Or you just wail on it... then wonder why it makes odd noises or why it's not as quick as you'd hoped :-)
Post by bigal1 on Jun 11, 2012 18:21:18 GMT 1
warm it up do about 25 miles but keep it out the power let it cool down a check the motor do this about 4 times then cain the fek out of it
Post by pepsisteve on Jun 11, 2012 21:45:38 GMT 1
did about 100 miles on mine, then nailed through 2-3 gears let it slow down again, then did it again and just sort of built it up realy, not held it flat out yet though!
phil38
Post by phil38 on Jun 11, 2012 22:05:02 GMT 1
Some load on the engine is important - limit the revs but not the throttle so much. Rings need some pressure obove them to get them bedded in
